Question about Sanyo DS27930 27" TV
Connected DVD player to Sanyo DS27930 TV via input
Connected portable DVD player to Sanyo DS27930 TV via input jacks. Cannot find way to change input on TV Menu or on remote control. No "input" button on remote control.
  • 290 Answers
According the manual for this TV the remote control has an input button, it is left of the power button. Make sure that the remote mode slected for TV not VCR or DVD and press input button to make a selction, make sure that the power to the DVD player is on. If yours is different try stepping through the channels buttons, some TVs input is selected through the channel buttons.
Posted on Jan 02, 2010
  • Nancy Jul 28, 2013
    Remote was lost years ago. Had an older DVD/VCR connected and it was with just the antenna cable.
6ya staff
SOURCE:
Sanyo tv model ds27930 not supporting my ps3
Whatever input you are using is either damaged or the tv is on the wrong channel and I'm sure you don't have it set on the wrong channel.
1. Another method would be to connect an old VCR to the TV through the cable plug on the back of the TV.
2. Then plug your PS3 or dvd player into the VCR's rca inputs on the back.
This works but your television has to have a cable plug on the back.
Oct 16, 2013 | Televison & Video
Can get tv to change to av1
The Input button on the original remote is needed to switch to the AV1 or AV2 connections. Unfortunately, I do not believe that the Sanyo DS27930 has an equivalent Input button on the TV. A replacement remote is available here: http://www.emtcompany.com/sanyo-ds27930-remote/rc64.html . Other universal remotes may be able to transmit the Input signal. You will need a remote that was programmed over 6 months after the TV was released with an Input or Source button. Then try all Sanyo codes until you find one that controls all of the features.
I hope this helps.
Mar 04, 2013 | Sanyo DS27930 27" TV
Sanyo TV connect to cable box connect DVD player
If your DVD/VCR combo player has three RCA connectors (yellow, red, and white), you can connect them to the corresponding inputs on the front of your TV.
Dec 29, 2012 | Sanyo Televison & Video
I would like to be able to connect the Zenith portable DVD player to my TV to watch DVD's on my TV. I have a model number ZPA-314.
If your DVD player and TV have RCA jacks, (3 wires: 2 audio, 1 video) simply patch between the two. If TV does not have RCA jacks, plug the DVD wires (3) into the 'line input 1' on VCR. This way, the VCR is acting as a 'converter' btwn. the DVD player and the TV.
Feb 05, 2011 | Zenith DVP615 Portable DVD Player
Have connected dvd/vcr but the tv screen is blue. Can you help please.
You MUST select EXTERNAL Input, NOT a Channel. You MUST connect up via, the INPUTS at rear, either COMPONENT, or COMPOSITE, Or, HDMI. Except for HDMI, ALL Cables, go Color Jack, to Color jack. 3 for composite & Audio, and 5 for Component & Audio.
Apr 23, 2010 | Sanyo DVW-7200 DVD/VCR
How do I change from TV to DVD/VCR Mode?
open the menu screen and go to input
Jun 24, 2009 | Sanyo DS27930 27" TV
Getting video form dav-dx to older sanyo TV with an S-video jack
Check what is input number of S-Video in TV and select that av input with TV remote.
Jan 23, 2009 | Sony Dream System DAVDX155 Theater System
The input button will not allow me to get to the video function
press the TV button on the remote then press input to sellect video mode
Oct 26, 2008 | Sanyo DS27930 27" TV
No progressive scan from component input
Sanyo DS27930 does not support progressive scan
DVD player must be set to interlaced scan
Nov 24, 2007 | Sanyo DS27930 27" TV
Tv connection
connect the composite video output of the player to the composite video input of your TV. The jack should be marked in yellow. Then connect your Audio input of the tv to the Audio out of the player.
Oct 09, 2007 | Philips PET710 Portable DVD Player
Sanyo DS27930 27" TV Logo
936 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
