Question about Kodak EASYSHARE G610 Thermal Printer
I have a kodak easy share photo printer 500. The right side (about 50%) of the images do not print. The right side of the part of the image that does print is a jagged edge of no image from top to bottom. Any advice on what could be wrong. I have tried several thermal cartridges and packs of paper. George
Posted by bkb1654 on
5 Related Answers
Anonymous
SOURCE: image prints on one side
Same problem here!
Posted on Oct 15, 2008
GZuraski
  • 31 Answers
SOURCE: kodak printer dock series 3
The problem is most likely a broken plastic lever on the end of the shaft that moves the print head. The plastic lever is keyed to the shaft by a flat on the shaft. The plastic has a tendency to split at the edge of the flat, resulting in the lever slipping on the shaft. This in turn results in one side of the print head not contacting the paper with sufficient pressure. The other end of the shaft has a thick plastic sector gear which is much less likely to break.
I fixed mine by making a clamp from a metal spacer (made from split tube about 1/8 inch long) and force fitting it over the part of the plastic lever that fits on the metal shaft (on the end towards the inside of the unit). There is just enough clearance to do this without hitting the print head frame.
To remove the plastic lever, first remove two screws from back of unit, then pull up on top of unit, unplug two ribbon cables from circuit board and remove top. Then unplug two remaining ribbon cables from circuit board, and three screws holding circuit board. Lift circuit board and fan/fan-holder as one piece. Finally, disengage tab on plastic retainer on end of metal shaft, rotate tab straight up and lift shaft up and to the side (may require a little wiggling). The plastic lever slides off the metal shaft.
Posted on Mar 20, 2009
Anonymous
  • 119 Answers
SOURCE: I have a Kodak Easy
Does the test print also print only half of the printer? If so, give Kodak a call - bad printer
If the test print works, try changing the usb cable.
Posted on Jul 11, 2009
Anonymous
  • 10 Answers
SOURCE: Printer dock does not pick up paper.
Try to clean the rubber rollers with lint free cloth. Make sure you are using Kodak Xtralife paper. At the back of the paper it should say "Xtralife".
Posted on Sep 11, 2009
Anonymous
  • 151 Answers
SOURCE: i have a kodak easy share z8612 IS and i lost
you can visit the Kodak website which is www.kodak.com/go/shop to compare different cameras
Posted on Sep 24, 2009
How do I get the date the picture was taken stamped on the picture
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Sep 18, 2014 | Kodak Cameras
How do I get the date to print on all the pictures all the time. My model is Easy Share M575
The camera stores the date and time (and a lot more) with every picture, but won't deface your images by putting a string of numbers across it.
Just about any photo viewing/editing program will show you this data. Depending on the program and printer, you can print the date on the image, in the margins, or on the back. Please refer to the documentation for whatever program you're using to view/print your photos. If you still can't do it, please feel free to reply to this post specifying the program(s) you're using.
Jul 14, 2011 | Kodak EasyShare C143 Digital Camera
Sheet feeder wheel marks on both sides of A4 photo prints
Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost. no need to switch over to any other brand.trust me Kodak is really good.
Jun 22, 2009 | Kodak ESP 5 Printer
Kodak EASYSHARE Printer Dock
Well it's not looking to pomising by reading all of the other people who are having the same problem. But could you please tell me how to fix my printer in is only printing half of my pictures no matter how many times i reprint them and it also doesn't pick up the printing paper very well i have to help it along. So if you could PLEASE tell me how to fix this problem on my own it would be greatly appreciated. Please respond As Soon As Possible Please and Thank You. I have the Kodak Easy Share Printer Dock Series 3.
Patricia Davis
Nov 03, 2008 | Kodak EASYSHARE Printer Dock Thermal Photo
Image prints on one side paper,kodak printer dock plus I have a printer dock that only prints on the bottom half of the photo paper. This dock is for a C533 Didgetal camara. Please help.
did you try to change the orientation to landscape or portrait? you can also check the printer properties and make sure that you have the right size paper selected
Aug 20, 2008 | Kodak Dock Series 3 Laser Photo Printer
Kodak easy share camerac 613
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date and/or time on the image, in the margins, or on the back.
Aug 01, 2008 | Kodak EasyShare C613 Digital Camera
Kodak 5100 only prints half the page
My Kodak Easy Share 500 decided to only print 1/2 the photo today.  For over 1 year it has worked just fine.  Any ideas?
Apr 28, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE G610 Thermal Printer Logo
107 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Ekse
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
