SOURCE: Paper pull only fron the right side
You may have a jam insude the unit. Open it up as if you are replacing cartridge, check everywhere for a tiny paper jam, with a torch, near roller, carriage etc. good luck xxx lilacgerry
SOURCE: Lexmark Z845 printer pulls paper sidw ways
I had the same problem with lexmark z845. It is easy to solve this problem.Just do like the picture I post and you never get the paper pull to one side again. The problem is the rolling motor is too strong, so it pull the paper out out the tray in oneside. I use the mini cassette box, stick it with the super glue. And the printer works very well
SOURCE: Printer will only pull the paper in from one side.
Hi !!
Usually this problem happens if there is something wrong with paper feed rollers which is inside the printer .
But to fix teh problem you can try this ---
take out ink cartridges, all the cables, power adapter (black rectangular box at the back) and papers from the paper feeder . Then take the printer in your hands, keep it like upside down and shake it for a while .Then keep it back in its position
Afetr 10-15 mins , install cartridges, cables, power adapter and just 1 sheet of paper on the printer . try to print somethg if still it dows same thg then it means that This is a time to buy a new printer on this christmas !!
Regards
Priya
SOURCE: Printer 2480- my printer is pulling paper only on right side
Try this :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
SOURCE: paper pulls in crooked with left side not pulling
This problem comes from the paper wheels. There are small size wheels that feed the paper into the machine. Once one of this wheels is slipping either you change just that wheel or you change the whole set of wheels. So I would take it to a repair shop to see how much it will cost. Other wise time to buy a new one. Good luck
