Question about Pulsar Chronograph Watch
The timer (stop watch) on my Pulsar Chronograph watch does not line up with the 12 when it is reset. I think it was knocked off center with very high magnatism. Is there a way I can manually reset it?
To set the timer hand on these models of Pulsar watches, do the following:
Looking at the face of the watch, there are two buttons and a crown on the right side. The TOP button is Button "A". - The BOTTOM button is Button "B".
There are 3 positions on the crown: IN (#1), FIRST CLICK (#2) & SECOND CLICK (#3).
First, pull the crown out to the second 'click' position (#3) ... This is all the way out. (STOP THERE! Pulling harder will harm your watch! Don't try to pull past position #3!)
Push and hold Button "A" for two (2) seconds. The dial will sweep around to the 12 O'clock position. You can advance the timer while the crown is in position #3 (second click out) to reset it back to the default position.
The manual says that if you pull the crown out to position #3 while the timer is measuring, the hand will reset back to the 12 o'clock position... I haven't tried that, so I can't confirm.
Posted on Mar 31, 2010
