HI. There is no such button present in your vehicle. There are only two ways to shutdown the check engine light. These options will only shutdown the light, temporally. The first option will be to power off your cabin radio, and pull the positive battery cable for 10 minutes. This will reset the CPU, thus , resetting the Memory. The code will be stored, and the light will shutdown for a short time. The second option will be to plug a diagnostic CPU into the diagnostic port, under the dash. This CPU will pull the codes, and give you the option to clear the alert. You must know that once the codes are clear, the CPU will notice the issue once more, during highway driving. Once this is noticed, the Check engine light will illuminate again.
In order to solve the issue, it is recommend to have the codes pulled. Once you have the codes, you will be able to isolate the problem area and have it repaired. This will permanently shutdown the check engine light, until the next error is discovered.
I just had a similar problem, light came on, I went to AutoZone, they plugged in the diagnostic computer and it threw no codes. It passed, the car runs great, but the check engine light is on and won't go off. I bought a new gas cap thinking that may be the problem. Filled the tank with premium and a bottle of engine clean, light is still on. I really don't wont to pay $80 to have someone push a few buttons to turn off a light. Also, I disconnected the positive cable from the battery, it didn't work. Light is still on. Help!!
There isnt one you need to disconect the batterie for 5 - 10 min then it will reset it self
