Question about UTStarcom PPC6700 Blackberry 8800, 7130v, 8707g,A1200 / MING,KRZR K1 / KRZR K1m / Nextel ic402 / ic502 Car Charger
How do I format my memory card to my phone? - UTStarcom PPC6700 Blackberry 8800, 7130v, 8707g,A1200 / MING,KRZR K1 / KRZR K1m / Nextel ic402 / ic502 Car Charger
Posted by ykinmon42 on
Dvdcdlaser
    President:
  • 1,285 Answers
You need to have the adapter to it..so that you can place in pc card reader slot....go to my computer find that drive and format...
note do not connect cell to pc while attempting to format
Posted on Jun 17, 2010
Im phon not format/delete
  • Prepare your memory card for formatting. Decide whether you would like to format using your phone or your computer. If you decide to use your computer, remove the micro memory card from your phone and place it into the memory card adaptor. If you decide to use your phone's removable memory card slot, insert the memory card into the phone while the phone is off, before turning on your phone.
  • 2Navigate to the menu and select your phone options. Locate the menu that includes the technical list; you should see "Media Card" or "Memory Card" listed as an option. If your phone has a separate menu for Memory options, look within this for your memory card menu option.
  • 3Access the memory card menu and click "Options." Be sure that memory card support is enabled. Next, select "Format." This may be found listed or you may need to click on the menu within the memory card menu you have already accessed. After selecting the format you may have the option to choose between formatting the media card and/or the device memory. Select "Media card" if confirmation is required. Keep in mind you will be losing any data previously stored on your card.
  • 4Select OK when your phone asks you to confirm format. Your memory card will now be formatting to your phone and a progress bar may appear. Do not power off or navigate away from this screen. When formatting is complete, your phone will notify you and the progress bar will no longer be visible. You may need to confirm with an "OK" that your memory card has finished formatting.
  • 5For Windows users who wish to format using a computer, place the micro memory card within the adaptor and insert it into your computer's memory card slot. You can also connect to your computer using an external adaptor if your laptop doesn't feature one built in. After connecting the memory card, select "My Computer" within your Windows menu. Select your memory card, which should be listed within this folder. Right-click on the menu and select the format. Your computer settings will prompt you to accept the format and complete the process.
  • sincerely. God bless you.
    ernesto cuadra
    managua,nicaragua.
    Dec 17, 2011 | Sony Ericsson Cell Phones
    How to remove virus from phone memory
    Have a blessed day. My name is dingra. There are a few things you can do to attempt to remove the virus from a cellphone.
    1.Format the memory card in your cell phone. It may actually be the memory card, not the phone itself, that is infected with the undeletable virus. On most phones, you can format the memory card directly from the phone by going to the "Options," "Settings" or "Tools" portion of the main menu screen on your cell phone. Consult the manual that came with your phone to learn exactly how to format the memory card in your cell phone. You can also find these user manuals directly on the manufacturer's website.
    2.Buy a new memory card for your cell phone. The undeletable virus may have damaged your memory card beyond repair. If formatting the memory card didn't fix the problem, getting a brand new memory card may fix your problem. These memory cards are relatively inexpensive and can be purchased at just about any store that sells cell phones.
    3.Format your entire cell phone. If getting a brand new memory card hasn't fixed your phone, formatting your cell phone should remove the virus and every other file on the phone. Before you attempt to format your cell phone, remove your memory card. Read the manual for your specific cell phone, as the instructions for formatting cell phones vary based upon the manufacturer of the phone. fir
    Hope it helps.
    Thank you for using fixya.
    Oct 01, 2011 | Cell Phones
    My mmc card is corrupted how can i format mmc card
    Hello DJB,
    Formatting the memory card is a easy process. You can format the memory card from the format option available in memory card option itself. You can also format the memory card using the desktop pc or laptop. Remove the memory card from the phone and connect the memory card in computer using the external memory card reader and format the memory card.
    Apr 15, 2011 | Nokia 6630 Cellular Phone
    I cant see any photos which are there in memory card in the gallery.
    If you cannot see the pictures on your phone, that is on the memory then you need to format it with the steps below but before that connect the memory card to your pc an save all data there first. when finished with the format replace them back to the phone
    NOTE: Format the memory card if you forget the memory card password. The device will allow you to format and erase the memory card password without asking for the password during the formatting process.
    To format the memory card:
    1. Press Menu
    2. Select Applications
    3. Select Office
    4. Select File Mgr.
    5. Select Memory Card and press Options
    6. Scroll to and select Memory Card Options
    7. Scroll to and select Format
    8. Select Yes
    NOTE: Format the memory card if it intermittently malfunctions (e.g. errors, file corruptions)
    The Formatting option will properly configure the memory card for use with the phone.
    Dec 05, 2010 | Nokia 5230 Cell Phone
    How to format nokia mobil
    To format the phone dial *#7370# from your phone. But, before you do that, backup all the data including the phone settings as you will lose all dat when you format the phone. And also remove the memory card from the phone before formatting. If you want to format the memory card then use the File Manager and from there select the memory card. Go to Options and you will find an option for formatting the memory card. Use this.
    May 19, 2010 | SanDisk 2GB microSD Memory Card
    I have nokia n73. there is a problem in its use. whenever i use it , it gives the message of memory full and asks me to delete some data. please tell me some solution.
    The phone's internal memory and memory card may be running out of space. Try to delete unnecessary files and free some memory space. Go to Menu>Tools>File Manager. Select the folder or file you want to delete and scroll left or right to switch from the phone's internal memory to the memory card.
    Format the memory card and the phone's internal memory if the problem is not resolved above. But it will erase all saved data on both memory.
    Memory Card Formatting Procedure
    1. Go to MENU > TOOLS > MEMORY.
    2. On the memory card menu press OPTIONS.
    3. Scroll to Format memory card.
    4. Press Select.
    5. Select Yes
    6. Once the formatting is complete, remove the memory card.
    Phone Memory Formatting Procedure
    1. On your phone dial *#7370#.
    2. Press Yes then enter your phone lock code. Default code is 12345.
    3. Formatting is complete when the phone restarts. Insert the memory card and format it again.
    Jan 15, 2010 | Nokia N73 Cellular Phone
    How can format the phone memmory of NOKIA 3230
    Download user guide from:
    http://nds1.nokia.com/phones/files/guides/Nokia_3230_UG_en.pdf
    Page 163
    When a memory card is formatted, all data on the card are permanently lost.
    Some memory cards are supplied pre-formatted and others require formatting.
    Consult your retailer to find out if you must format the memory card before you
    can use it.
    • Select Options→ Format mem. card.
    Select Yes to confirm. When formatting is complete, enter a name for the
    memory card (max. 11 letters or numbers).
    Backing up and restoring information
    To back up information from your phone’s memory to the memory card, select
    Options→ Backup phone mem.
    To restore information from the memory card to the phone’s memory, select
    Options→ Restore from card.
    You can only back up the phone memory and restore it to the same phone.
    Locking the memory card
    To set a password to lock your memory card to help prevent unauthorised use,
    select Options→ Set password.
    You are asked to enter and confirm your password. The password can be up to
    eight characters long.
    Your rating would be most appreciated.
    Feb 20, 2009 | Nokia 3230
    MMC memory card is corrupted (1GB). does not format.
    Please try to format the memory card using a memory card reader on computer and then insert the card back in phone, it will say corrupted again, but now you try again to format it from phone and it should work now,,.....
    Nov 06, 2008 | Nokia 6600
    FORMATTING A 1MB MEMORY CARD FOR SAMSUNG D900i
    The memory card is pre-formatted. If a memory card needs formatting the phone will request that you format the memory card (the menu for this will appear on the phone). You can't re-format it. Memory status
    You can check the total amount of memory for media items and the amount of memory currently in use in each media box.
    Your phone is preset to use FAT16-formatted memory cards.
    If you insert a FAT32-formatted memory card, the phone will ask you to reformat the
    memory card. If you do not, you will not be able to access the card from the phone. If a folder on a memory card has sub folders which exceed the maximum folder depth supported by your phone’s file system, you may not open or delete the maximum depth sub folders on the phone.
    Frequent erasing and writing will shorten a memory card’s lifespan.
    • Do not remove a memory card from the phone or turn off the phone while data is being accessed or transferred. This could result in loss of data and/or damage to the card or phone.
    • Do not subject memory cards to strong shocks.
    • Do not touch memory card terminals with your fingers or metal objects. If dirty, wipe the card with a soft cloth.
    • Keep memory cards away from small children or pets.
    • Do not expose memory cards in a place subject to electrostatic discharge and/or electrical noise.
    Apr 04, 2008 | Nokia 6288 Cellular Phone
    UTStarcom  PPC6700 Blackberry 8800, 7130v, 8707g,A1200 / MING,KRZR K1 / KRZR K1m / Nextel ic402 / ic502 Car Charger Logo
    59 people viewed this question
    Top UTStarcom Cell Phones Experts
    Marvin
    Marvin
    L Vincent Testa
    L Vincent Testa
    Andrew Taylor
    Andrew Taylor
    Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
