Question about Visual Audio Players & Recorders
Charging VL-535 Dear expert! I can't understand how would be correct to charge my player? do it have to be switched on when it is connected to PC by USB? I read in my User's Manual, that in System Settings must be "Battery Charging" but I haven't got it in my player's System Settings! how should I charge it correctly? Thank You.
6ya staff
SOURCE:
Anonymous
SOURCE: RCA Pearl TH1101A MP3 player not charging battery
the rca pearl does not have an external power source, only the AAA battery. Just put in a new AAA and you're good.
Posted on Feb 22, 2008
Anonymous
  • 83 Answers
SOURCE: charging problem on 2002 929 rr1 blade
I'm thinking your battery is the wrong ah. 8.6 for that type motorcycle is quite low. I would expect around 12 - 14 ah. Actually you should not be draining the battery though. The problem may be in the alternator assy its self. Have you checked all three legs of the charging system coming from the stator? I have found the stator to be the culprit many times in this situation. The bike should not be draining the battery at all if the alternator is charging correctly. What was the oem battery ah that you replaced?
Posted on Nov 30, 2008
Anonymous
SOURCE: Av1 I - scream mp4 player
AV-1 has built in battery you cannot replace it
Return it to shop if still under warranty - batteries are known to be dodgy with this player, I have one...
Posted on Mar 05, 2009
Anonymous
SOURCE: Yamaha FZR 600 not charging correctly with the lights on
I HAD THE SAME ISSUE. CHECK YOUR VOLTAGE OFF O THE MAGNETO, IT SHOULD BE IN THE 25V RANGE. IF THAT CHECKS OUT OK CK THE VOLTAGE IMEDIATLY AFTER THE VOLTAGE REGULATOR, I BET IT IS BELOW 14V. THE FZR IS PRONE TO HAVING THE REGULATOR GO BAD (THE OLDER ONES HAVE NO COOLING FINS AND THEY BURN THEMSELVES UP). THE BEST ONE TO BUY IS THE NEWER VERSION FROM A 1999 FZR, IT HAS COOLING FINS WHICH GREATLY PROLONGS THE LIFE. YOU HAVE TO DO SOME SLIGHT WIRING MODS, BUT NOTHING ANYONE COULDN'T DO. SEARCH FOR FZR REGULATOR UPGRADE AND IT WILL EXPLAIN EVERYTHING! I HOPE THIS HELPS! GOOD LUCK!
Posted on Mar 22, 2009
  • 102366 Answers
SOURCE: need a user manual for a new visual land vl-g4 mp3
You can download a copy of the manual from the manufacturer's web site at http://www.visual-land.com/downloads/5x7_manual.pdf
Posted on Jul 12, 2010
Addapter connected but not charging for sharp VL-Z500
If not charging,3 reasons may be-
1.Charger is defective.Check adapter
2.Batt is defective.Try with another one
3.Camera is electrically dedective.Can't complete charging.
Oct 20, 2012 | Sharp VL-Z500H Mini DV Digital Camcorder
Hello i have a mp4 media player, my problem is that no turn on the batery is ok when i put the select in ON the media player no turn on i try to connect in to the pc but no conected to can you help me
Good morning, afternoon, evening or night; whatever time of day you are viewing this. Thank you for choosing FixYa to solve your problem. Your problem is that your MP4 player will not come on, even when you connect it to your PC? Well, you should try recharging your battery. There are two ways you can charge this device using your USB cable. The first way is by connecting the USB cable to your PC. Charging will take 8 hours by this method. The second way is connecting the USB cable to the wall charger that was supplied with your media player. If you had a problem connecting to your PC, you should try charging via the wall charger. Charging is much faster this way than using a computer. If charging doesn't turn your device back on, your battery may be defective. If that's the case, you'll need to get the battery or your media player replaced. Hope it's just a recharge that's needed. Thank you for choosing FixYa as your one-stop solution spot for your problems. Have a good day, afternoon, evening or night; whatever time of day you are viewing this. Come back and visit our site again whenever you need assistance!
Apr 29, 2011 | Visual Land VL-853 Digital Media Player
Blank screen wont turn on or off
Make sure player is fully charged. Connect the player to the PC. Make sure the computer detects the player.
NOTE: You may need to switch the player to MSC mode, then connect it to the PC.
Leave the player connected for approximately 2 hours to charge. Disconnect the player from the PC. Verify if you can turn on the player. Reset the player if necessary. Then you may need to reset the player. Slide and hold the Power switch up for approximately 20 seconds. Release the Power switch. To turn the player on, slide the Power switch up then release right away.
Feb 14, 2010 | SanDisk Sansa e250 MP3 Player
My sansa will not turn on
NOTE: you may need to switch the player to MSC mode, then connect it to the PC.
Leave the player connected for approximately 2 hours to charge. Disconnect the player from the PC. Verify if you can turn on the player. Reset the player if necessary. Reset the player. To reset -- Slide and hold the Power switch up for approximately 20 seconds. Release the Power switch. To turn the player on, slide the Power switch up then release instantly.
Feb 14, 2010 | SanDisk Sansa Fuze MP3 Player
Mp3 player froze when plugged into pc. screen is blank but lit. is charged. what do i do?
Make sure the player is fully charged.
  • 1. Connect the player to your computer.
  • 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode,
  • 1. Turn device OFF.
  • 2. Slide the Hold switch down to Lock (orange color showing).
  • 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC.
Next Be sure the battery is charged
  • 1. Leave the player connected for approximately 2 hours to charge.
  • 2. Disconnect the player from the PC.
  • 3. Verify if you can turn on the player.
  • 4. Reset the player if necessary.
To reset the player:
  • 1. Press and hold the Power/Menu button for approximately 20 seconds.
  • 2. Release the Power/Menu button.
  • 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Then try and see if it will come on with out the battery but hooked to your computer.
Feb 02, 2010 | SanDisk Sansa e250 MP3 Player
My mp3 player doesn't turn on even if I charge it. Do you think I need a new battery?
Make sure the player is fully charged. 1. Connect the player to the PC. 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, to switch the player to MSC mode
1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Skip this step if you think it is charged. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary. To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
Jan 30, 2010 | SanDisk Sansa m230 MP3 Player
Without warning and without any impact or damage, it just stopped working, no power, nothing. And it's not a battery issue, the battery was almost completely charged.
Try and reset again.
1. Slide and hold the Power switch up for approximately 20 seconds.
2. Release the Power switch.
3. To turn the player on, slide the Power switch up then release instantly.
Part 2 - Make sure the player is fully charged.
NOTE: This part is important:, switch the player to MSC mode, then connect it to the PC.  3. Leave the player connected for approximately 2 hours to charge.
4. Disconnect the player from the PC.  5. Verify if you can turn on the player.  6. Reset the player if necessary one more time.
Jan 08, 2010 | SanDisk Sansa Clip MP3 Player
Mp3 player wont charge or turn on
i have the vl 868 and it would only turn on with the charger in- not when it was unplugged. it took me awhile- you have to turn the switch on and then hold play for like 4-5 seconds for it to turn on.
Apr 09, 2009 | Visual Land V-Bop MP3 Player
Trouble
To resolve this problem, establish that the player is charging correctly as follows:
  1. Connect the player to a USB port on the back of a desktop PC, to a powered hub, or to a power adapter (separately available).
  2. Check the display for the charging icon battery_ac_charge_1.jpg.
    • As the display times out after a few seconds, press any button on the player to reactivate the display.
    • If the battery is fully depleted, the charging icon may not be displayed. Cup the player in your hands to check that the blue power LED behind the Play/Pause and Options buttons is glowing on and off repeatedly. This indicates that the player is successfully charging. After 1 hour of charging, power on the unit to activate the display. The charging icon should be displayed.
  3. Allow the player to charge for at least 6 hours. During this time, if charging from a USB port, please ensure your PC does not enter a power conservation mode (Standby, Sleep, or Hibernate) as this will interrupt charging.
If the player does not indicate a charge, or will not power on after at least 6 hours of charging, please contact Customer Support.
Creative recommends updating your ZEN V or ZEN V Plus firmware to take advantage of new features and functionality. To learn more, click here.
Hope this helps
Chris (ziraffa)
Jan 06, 2009 | Creative Labs ZEN V Plus MP3 Player
Just got it
hold down "Play/Pause" with hold switch off.
Sep 23, 2007 | Apple iPod nano
Top Visual Audio Players & Recorders Experts
Ekse
Jerry Greenberg
Jerry Greenberg
Phil Whisenant
Phil Whisenant
Are you a Visual Audio Player and Recorder Expert? Answer questions, earn points and help others
