Question about Ice-O-Matic ICEU220HA Undercounter Ice Machine
I have an under-counter ice-o-matic model #IFQ-1 only a couple years old. It makes a quantity of ice but then freezes over too thick, water stops running and the ice cubes won't drop out. Any suggestions?
Posted by goodtogox on
Chandler Ede
  • 1,420 Answers
Have you cleaned the unit lately. There is an ice thickness probe that can be adjusted to compensate.
Posted on Jan 17, 2010
How do I adjust bridge thickness on ice o matic
Adjust the Timed freeze. The freeze timer is an adjustable timer used to control the ice bridge thickness. The freeze timer is factory set but may need to be adjusted upon initial start up of the machine. When time is added to the freeze timer the length of the freeze cycle is increased, therefore the ice bridge thickness is increased. When time is removed from the timer, the freeze is shorted and the ice bridge thickness is decreased. The freeze timer can be adjusted by sliding one or more switches to either the ON or OFF position to 1/8'' ( 3mm ). If bridge is too thick remove enough time from the timer to achieve proper thickness. If bridge is to thine add enough time to timer to achieve proper thickness.
NOTE: The freeze timer on ECP models is located on the circuit board. It operates and is adjusted as described above. Now if you have had this machine for awhile and it was making the right bridge thickness and is now making thinner ice i would look at the purge valve to make sure it is not letting water seep out of the sump tray during freeze cycle this will cause the sump tray to keep filling up with water and will cause thin ice.
Sep 15, 2014 | Kitchen Appliances - Others
I have a ice-o-matic 400ha2 ice machine that is not making much ice and is to thick. the timer has been replaced,but no change
reduce the thickness thermostat that initiates the timer to minimum, then increase until good ice made.
Aug 29, 2014 | Kitchen Appliances - Others
Ice o matic troubleshooting
If you have tried to take some time off of the freeze timer and bridge thickness is still to thick then depending on model.
1. Replace freeze timer.
2. Some models the timer is on the control board if so then you will need to replace the board.
Aug 27, 2014 | Kitchen Appliances - Others
How can i fix my manitowoc qm45a runs water but won't freeze the water?
The thickness sensor is shorting, making the machine continually harvest. Clean it and dry it. If it still happens, replace the sensor.
Aug 05, 2014 | Manitowoc Compact Undercounter Ice Machine...
I have a ice o-matic model iceu220ha1 freezes but will not go into harvest
Go to Google put in model number ICE220ha1 when it comes up the fourth one down, Service parts manual The ice series under-counter... It is a PDF down load it then go to trouble shooting look for not going into harvest this will tell you what to look for.
Oct 24, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
Ice to thick
your machine should have a bridge thickness of 1/8 of an inch. you can go to the freeze timer and take some time out to shorten the freeze cycle buy sliding the switches to on and off. example if switch is set to on at 18 then you wont to turn that switch to off and turn the next lowest number switch to on until you achieve the right thickness of ice. if this dose not work then replace freeze timer.
Apr 19, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
ICE-O-MATIC ICEU220HA2 bridge too thick. Is the time delay relay the "finnish" relay that adjusts bridge thickness? If so, I'm not getting any change in thickness with time adjustment.If the time delay...
The bridge thickness on this model starts with the low pressure cut-in control that then in turn starts the timer. To start with if you have a low pressure gauge that you trust what I do is take all of the time off of the timer and unplug the water pump. Then start the unit and watch the low pressure gauge to see at what pressure the harvest starts. an ICEU220 with R-404A should cut in at 45psi. Once that is set plug the water pump in again, put about 400 seconds on the timer, see how thick the ice is after 2 cycles and adjust as needed.
Apr 06, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
Under counter sub zero ice machine. stoped making ice
Try this! Clean water tube, Check Ice sensor ( small wire (red tip) set to close to ice plate ) To close ,no build up sets off to soon.
Dec 11, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero Under Counter Ice Maker not making Ice
ice stat defective
hot gas solenoid vavle defective
pls post make /model.
if ignis / whirlpool then above points should the trick.
lastly reclaim gas replace both driers recharge with fresh gas to spec( liquid by weight).
Feb 20, 2008 | Freezers
Ice-O-Matic ICEU220HA Undercounter Ice Machine Logo
667 people viewed this question
Top Ice Kitchen Appliances - Others Experts
Dennis
NOEL
NOEL
Are you an Ice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
