Hi, i just got a used ps2 from a friend, i was playing it and the game froze, but when i resetted the system it wouldnt spin the disc, it would say "Reading disc" for about 2 seconds then quit, any advice?
i suggest get money back but you could try to clean the lens and see how that works
or call the sony customer service for advice. heres their hours and number:Sony Computer Entertainment America M-SAT 6:00 a.m. - 8:00 p.m. PST Sunday 7:00 a.m. - 6:30 p.m 800-345-7669 (800-345-SONY) i suggest get money back but you could try to clean the lens and see how that works
You can't post conmments that contain an email address.
The only possible reason for your problem, since your slimline ps2 is STILL reading them (but just a little slow sometimes), is because the lens could hardly read your discs due to dust build up. Try cleaning it using a disc cleaner and letting it spin for like 30 seconds. If this does not fix the issue, then you may have to MANUALLY clean the lens. Open the cover and once you see the lens, get a clean swab or qtip and damp it in an alcohol and gently wipe the lens in a circular manner. Then let it dry and try to play those discs again.
Please let me know how this goes. Thank you for using FixYa.
A Ps2 Will Only Play Ps One Games That Is All It Will Play It Also Play Mp3 Disc's And Dvd's The Xbox 360 Play Xbox Games, The Nintendo Wii Play's Nintendo 64 Games, The Ps3 Play's Ps One Games And Ps2 Games and The Nintendo Ds Plays Gameboy Games
I just looked at a friend's PS2. Same story, tripped over cord, unit fell to floor. Unit powers up and sys. config. screen comes on but the drive didn't seem to be spinning up. Opened the case and found that the shaft of the drive motor for the laser tray had popped out of it's centering retainer ( little black bushing/holder). With the top off the unit, looking at the unit from the front, on the right side in the rear corner you'll see the motor. The worm shaft (bronze colored rod) runs towards the front of the unit. Where it ends it should sit centered in a black plastic holder, if it's off to the side a little pressure will pop it back in. Put the cover back on, and power it up, you should hear the drive spinning up. If it does you should be set. Hope this helps.
it seems there has been a malfunction within your CD Drive, this is what is causing the CD drive to not spin or read the disc. these problems can be only generally resolved by either getting the console repaired/replaced unfortunately.
The PS2 will still turn on and run because the CD Drive does not dictate whether the console works or not, but because the CD Drive is broken, you will not be able to play games or watch DVD Films unless you have the CD Drive Repaired.
my friend i have a ps2 that its cd does not rotate ( i open it completely ) and the lens is working the lens is producing a red ray and it is movinng up and down but just the cd motor doesnot rotate so i checked the smd fuses using my fluke dgital multimeter i found one that is open when i replace it the ps2 work perfectly fine for your information the smd fuses are marked ps1 ps2 ps3 ps4 etc
