Question about Magellan Roadmate 1200 Car GPS Receiver
First time using Magellan RoadMate 1200 the screen will not go any further than USB connected screen. Tried to update it from the website. Still nothing! Any suggestions?
Anonymous
    New Friend:
Nevermind. I found out that it just needed to be charged. Everything is working great now.
Posted on Jan 03, 2010
My Magellan RoadMate 1340 will power up to logo and "moving clock
Have you tried updating the software on your device.
Go to Magellan.com and download the Magellan Content Manger:
http://www.magellangps.com/products/map.asp?tab=0&PRODID=2216
Once you've installed Content Manger onto your PC, connect your device to your PC using the USB cord. The Content Manager will allow you to update your 1340 with the latest software and updates which 'should' fix the problem that you're having with your unit.
Apr 04, 2010 | Magellan RoadMate 1340 GPS Receiver
Need an update for magellan roadmate 1200
Magellan® RoadMate® 1200 Software Update Version 1.50/3.12 - Release Notes This update applies to Magellan RoadMate 1200. It includes the following features, fixes, and improvements:
Improvements:
  • Point of interest (POI) Search Improvements reduce POI search times
  • Map Draw Improvements improve zooming, panning, and time to display the map
The software update version corresponds to your current software version:
  • If you have software version 1.46 or 1.48, your software will be updated to v1.50.
  • If you have software version 3.10, your software will be updated to v3.12.
You can locate your software version by following these steps:
  1. Start at the Main Menu.
  2. Press the arrow on the bottom right of the screen.
  3. Select "User Options"
  4. Select "System Settings"
  5. Select "Next"
  6. Select "Product Information"
  7. Your software version is on the line titled "Firmware Version"
Download Update: (Click here:)
I WANT TO DOWNLOAD THIS UPDATE
Feb 07, 2010 | Magellan Roadmate 1200 Car GPS Receiver
My magellan roadmate has a small ding on screen. I will not respond to touch on certain screens. Can it be taken appart for repair?
yes it can, but youll have to get the lcd with the digitizer, because the are soldered on the the lcd and very difficult to replace.
you can buy a good used, but broken 1200 off ebay for under 20.00 normally, because the 1200 has a problem with the usb port becoming damaged or broken and ask the seller if the screen is good
you can also by a new screen but its harly worth it, since yyou can buy a new 1200 for under 70.00
if you need further help, just reply to this post
bill
Jan 04, 2010 | Magellan Roadmate 1200 Car GPS Receiver
Tried to update the firmware on the Magellan 1470
Just got off the phone with Magellan East (my guess is India as I had a hard time understanding them and said "What?" 20 or 30 times) to which they said that there is no way to reboot these systems. I updated to 2.20 and it froze my GPS. I have to send my unit back to them and they are sending me a refurbished one free. I am outside the warranty period according to them but have AAA, which gave me an extra year on warranty, so they are honoring it. Give them a call at 8007079971 to get this fixed.
Nov 28, 2009 | Magellan RoadMate 1470 GPS Receiver
Can you download an update for a magellan roadmate 1430?
Yes you can: Enter your info here http://www.magellangps.com/support/
English Manual: http://docs.google.com/viewer?url=http%3A%2F%2Fwww.magellangps.com%2Fassets%2Fmanuals%2Froadmate_1430_manual_en.pdf
Magellan® RoadMate® 1430 Software Update Version 3.12: http://www.magellangps.com/support/chooser.asp?prodid=2056&supportid=806
2009 Spring Map Update: http://www.magellangps.com/products/map.asp?tab=0&PRODID=2194
As for connecting it to the computer, you'll need the usb cable that came with it. Then you'll want to do this:
Follow these steps to connect your Magellan RoadMate to your PC.
  1. Turn ON your Magellan RoadMate.
  2. Touch "Map" to display the map screen.
  3. Connect your GPS to your PC using the USB cable.
Oct 19, 2009 | GPS
I pluged in my Magellan Roadmate 1200 in to the computer with the usb cable thinking it would charge. It now says it has a fatal error and that screen won't go away. Did I erase the memory on it? I...
im sure its not trash, but i dont think the usb will charge this model ( the usb wont charge all models of magellan, only some) while the unit is on, use a paperclip and insert it in the small hole on the side of the gps, that should return it to its normal state.
if you need further help, just let me know.
bill
Sep 03, 2009 | Magellan Roadmate 1200 Car GPS Receiver
I just got a Magellan roadmate 1200 over the weekend from a friend and when I plug it in it loads to a screen that says the usb is connected follow pc instructions
The USB must be for charging the unit and downloading updates when it becomes available. You have to unplug the USB and use the battery power to put in addresses .My 1200 does the same.
Jan 05, 2009 | Magellan Roadmate 1200 Car GPS Receiver
How to program Magellan RoadMate 1200?
Go to www.magellangps.com. Click on "Support" on the top of the screen. On next page, go to "Product Support and Updates" on the right and enter the "Family" (Magellan RoadMaster Series) and the Model should automatically pop in the box (Magellan RoadMaster 1200 - US). Then, click "Submit". On the next page, go to "Manuals" and select "In English" and click. The manual will automatically start to download. Hope this helps...
Aug 31, 2008 | Car Audio & Video
Magellan Roadmate 1200 Car GPS Receiver Logo
544 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Magellan GPS Expert? Answer questions, earn points and help others
