This is probably a little late but I'm assuming you have an outside tank. When you had it refilled it may have stirred up the gunk in the bottom of the tank. You should check your filter at the tank if you have one. You should also check the strainer in the fuel sump in the heater that is located on the right side of the heater where the fuel reset is. You should shut the valve at the tank before you do this and be prepared to catch or soak up any kerosene that will come out. The strainer is located behind a small plate with 2 screws holding it on.
