I just re-capped my 9 volt supply and now the tv will come on but then the screen will go blank and the buttons are unresponsive, including the power button. I had previously recapped the TV with great success but I ended up not having all of the caps namely, C2P00, so I made due with a SMT cap. The screen started to bounce again, so I decided to order the correct cap. I Intalled that one and I nodiced that I had placed one of the caps in backwards, according to the silkscreen. So, I got a new one out and replaced it in the correct orientation and this is where I am at.......
SOURCE: flashing green button, won't reset or turn on
Steps to fix your TV: http://www.chrisandnat.com/temp/BlinkingTV.pdf
i held menu and device for about 10-15 seconds on my WS-55515 and the blinking went away and my tv works just fine after that
SOURCE: Mitsubishi HDTV 1080 WS-55859. Error Code 12
Did you push in the device and the menu buttons at the same time and get the error code... I have the same problem and I get a 1,2 code.... I am looking for what the codes stand for...
Have you got any help on this....
Scott
mu email is [email protected]
SOURCE: Blinking Green light after Capacitor kit replacement WD-62725
I just repaired two Mit WD-62725 sets in the last two weeks.
The first one had bad caps on the power board and the FMT board. The scond one had bad caps on four out of the five boards.
Also, on the FMT board, there was a blown surface-mount fuse.
I advise checking all of the boards for bad caps. If you fine a bad 1000uf cap, replace all of the 1000uf's on the board.
Hop this helps,
Dan
Testimonial: "Great comments. Quick to respond!"
