SOURCE: audio via hdmi
I had the same problem with the same configuration. In addition to the HDMI which is (DVD and Audio OUT only by the way) you need to connect the TV to the DVD through a high quality SCART cable as well. Remember to connect the SCART cable only while both the TV and DVD are switched off. To get the TV sound out of the DVD surround sound you need to click the FUNCTION key on the DZ230 remote a couple of times till you get the word TV on its screen, this is when you should hear the TV sound coming out of your surround sound as expected. Good luck.
SOURCE: No Audio on 32 Inch LCD Flat Screen
We have the same issue with our Insignia HDTV. The solution (which is not a solution) on our set is to switch the input to any of the other choices then switch back to Component 1 which is where the cable box is input.
SOURCE: no video. just snow on the screen. audio works
I would try and delete everything off your xbox360's hard drive and try it again. something during the transfer might have corrupted the data. Corrupted data can screw with all kinds of things. Just something you can try on your own without help from microsoft.
SOURCE: HELP!!!!!!!-CHANG JIANG N958 R33240
Dear Sir I have n958 model Cell
then i want software of that mobile
SOURCE: go video VR4940 VCR video recording has sound but no picture
You can try cleaning the video tape heads. The vcr has 2 different heads. One for audio which is fixed and a drum head for video with 2 heads on it that rotate. The best way to clean them is to take a lint free cloth ad wrap it tightly around your finger. Put some alcohol on the cloth and place it on the drum. Then rotate the drum as you hold your finger against the drum. DO NOT move your finger up and down as you can brake the head off. The other option is to go buy a head cleaning stick. It's a piece of chamie on a plastic tongue depressor. I've cleaned hundreds of them with my finger though. You can clean the whole tape path with the rag. Good Luck.
