My epson stylus dx7450 shows me that i have all empty cartridges in it. i replaced them with new cartridges (all are non-genuine inks)and it still shows me that they are empty. I tried reinstall driver, unplug-plug usb or power... nothing works... is it software problem or hardware ?? pls help me
Solution 1
Once you remove the ink cartridge from the printer, you can make use of the Isopropyl Alcohol, and put at maximum of 10 drops in the ink cartridge. You will find a hole there, in which the ink usually runs from the ink cartridge to the head of the printer. When done, you can put the cartridge back in the printer and run the auto cleaning process from the printer's option in order to clean the blocked holes of the cartridge. I would suggest you to run print tests first and once you are satisfied with the results, you can start using the printer normally.
If you want to go further:
* Remove the tank.
* Connect a hose directly on the inlet ink.
* Locate the sensor of reservoir and press it to make as if a cartridge is available.
* Close the cover of the print head and clean the head by injecting air (under pressure) through the pipe.
* Replace the tank up and do a test print.
* Repeat the procedure several times if the nozzles are clogged.
Solution 2
Using a syringe and some alcohol to unblock the holes can also be very effective.
* Step 1: Remove the cartridge from the computer
* Step 2: With the syringe, take in some alcohol and put in some drops in the tiny hole where the ink runs from the ink cartridge to the head of the printer.
* Step 3: When done, put the cartridge (only where the tiny holes are found) in some warm water. If some ink runs in the water, it means that the holes have been unblocked.
* Step 4: Hence, let the alcohol act for 20 minutes on the ink before putting the cartridge back in the printer.
* Step 5: Run some test prints before using the printer normally.
Note: I would suggest you to do an automatic head cleaning each time before any printing task. Hence it will reduce the risk of having the print heads blocked by dried ink.
Please dont forget to vote this answer was helpful
Many thanks
