My viking oven had same issue - I needed to replace the ceramic ignitors (if ignitors fail to heat up properly the gas valve remains partially closed). Apparently they are intended to be replaced every 3-5 years. Also inspect and clean the oven burners - mine had corroded somewhat and prevented the flame from 'moving' to the opposite side - ie only half the burner was lighting. If you are handy the ignitors are very easy to replace - one screw, two wires each.
SOURCE: Our oven is not heating up past 150 degrees. The
The element will have to be replaced if there is no power going to it.
SOURCE: Oven won't heat past 150 degrees.
you either have a bad bake element or control. also check wiring between
