Question about Olympus m:robe MR-500i MP3 Player
M:robe & windows vista; installation cd lost
M robe doesnt work (data base error) and i have no more installation cd
Posted by sony_davis on
Blank/black screen after "Welcome" screen
you can try to fix the issue by woftware such as Windows Boot Genius, it is a multiple windows repair tool which can be used to fix all computer errors, create bootable CD/USB, recover data lost and unlock windows password, etc.
FreeDownloadAddress:
http://www.windowspasswordsrecovery.com/windows-boot/
Mar 05, 2013 | Toshiba Satellite® X205-SLi6 PC Notebook
Tip
Lost Windows Vista Password: Top 3 Tips to Reset Vista Password
It's well known that Windows Vista is more secure than previous Windows versions like Windows XP. So if you lost Windows Vista password, you'll find some effective methods used to reset forgotten Windows XP password cannot work. Well, does that mean one have to reinstall your computer once you lost Vista password? Of course not, there are still opportunities to reset your <a href="http://www.resetwindowspassword.com/lost-windows-vista-password.html" style="font-weight: bold;">lost Windows Vista password</a> with the help of third-party software. Besides, you can also reset lost Vista password in seconds if you create a password reset disk in advance.<br /><br /><span style="font-weight: bold;">1. Commercial Windows Password Reset Software</span><br /><br />If you search on Google to find a solution to your lost Vista password, many commercial Windows password reset tools will appear in your search results, like <a href="http://www.resetwindowspassword.com/" style="font-weight: bold;">Windows Password Reset</a>, Windows Password Unlocker, Windows Login Recovery, etc. With such a Windows password recovery tool, you can get instant access to your locked Vista computer by burning a bootable CD/DVD or USB flash drive. The biggest advantage of Windows password reset software is that common users with little computer skill can easily reset lost Vista password in 5 minutes according to the user guide.<br /><br />Take Windows Password Reset for example. As one of the best Windows password recovery software, it can reset lost Vista password in 4 simple steps.<br /><br />Step 1. Download and install Windows Password Reset Professional.<br /><br />Step 2. Burn a bootable CD/DVD or USB flash drive.<br /><br />Step 3. Boot the locked PC form CD/DVD or USB.<br /><br />Step 4. Reset lost Windows Vista password to be empty.<br /><br />It's worth mentioning that it supports all popular Windows OS, including Windows 7/Vista/XP/2000 and Windows Server 2008/2003.<br /><br /><span style="font-weight: bold;">2. Free Windows Password Recovery Tool</span><br /><br />If you don't want to pay to recover lost Vista password, you can find some free ones. Ophcrack and Offline NT Password and Registry Editor are the most popular Windows password recovery tools. Ophcrack is a free Windows password cracker based on rainbow tables. When you use this utility to recover lost Vista password, please note it'll take you much time to download it and passwords greater than 14 characters cannot be cracked.<br /><br />Offline NT Password & Registry Editor is not only a Windows password recovery tool, but also an almost fully functional registry editor. But it is completely text based which is a little inconvenient.<br /><br /><span style="font-weight: bold;">3. Windows Vista Password Reset Disk</span><br /><br />A password reset disk can help you reset lost Windows Vista password as long as you create it before losing Vista password. If you don't have one, just follow the instructions to create one (a USB flash drive required).<br /><br />Step 1. Click Start, Control Panel, User Accounts and Family Safely, and User Accounts.<br /><br />Step 2. Click Create a password reset disk on the left pane.<br /><br />Step 3. Click Next and follow the forgotten password Wizard to create a Vista password reset disk.<br /><br />When you enter a wrong password on Vista logon screen, the Reset password link will appear. Just click on it to pop up the password reset wizard, then insert your password reset disk in computer and click Next on the wizard to change your lost Vista password in seconds.
on Jan 24, 2011 | Computers & Internet
Hi! im using windows 7 starter, can i used vista as my new os?
ye you can, it mean you must downgrade your pc, use vista cd to install it, but you may lost your data at drive C: you must back up your drive c: data before install vista
i hope this helpful
thank you for using fixya
Jan 30, 2011 | Computers & Internet
How do i wipe laptopt and restart fresh?
You need to have the OS CD to do that. More often than not once the CD is inserted the installation process should in case it doesn't start then you need to change the Boot Sequence and the complete step is mentioned below.
Its Simple you are sure to like it.....Try it Out....Good luck
Go into your Bios/Setup, or Boot Menu, at startup, and change the Boot Order to make the DVD/CD drive 1st in the Boot Order, then reboot with the disk in the Drive.
At startup/power on you should see at the bottom of the screen either F2 or DELETE, to go into Bios/Setup, or F12 for the Boot Menu
http://support.microsoft.com/default.aspx/kb/918884
MS advice on doing clean install.
http://www.theeldergeekvista.com/vista_clean_installation.htm
A Tutorial on doing a clean install
http://www.winsupersite.com/showcase/winvista_install_03.asp
Windows Vista Installation Super Guide
After installation >Go to your Laptop/Computer Manufacturer's website > Drivers and Downloads Section > Key in your Model number > Look for latest Vista Drivers for it > Download/install them.
Save all Data, as it will be lost during a clean install.
Nov 16, 2010 | Microsoft Windows Vista Ultimate Edition
I have a Dell Photo 924 printer & my scanner always worked fine with my Windows XP. Switched to new Dell computer with Windows Vista & scanner, Dell All In One, did not show up at all. I got a...
sometimes there are compatibility issues with windows vista. Uninstall all other exisitng drivers of printers. Install the downloaded driver again and the software too. If it doesnt work then i think you must get it back with xp.
Jul 28, 2010 | Dell 922 All-In-One InkJet Printer
"Windows vista booting corrupt"
try to boot ur laptop with disc manager cd or win XP.
if doesnt works then try win 98 cd and delete ur C:/ partiton and install new vista
Apr 18, 2009 | Lenovo 3000 N500 Notebook
My Olympus m:robe MR-500i MP3... Problem:
try:
click Start>Run then copy and paste the following:
C:\Documents and Settings\Username\Application Data\
replace 'Username" with the name of your user account and press enter
In the new window, find olympus and make sure there are no important data in it and delete the folder
then do the same in
C:\Documents and Settings\Username\Local Settings\Application Data
You will need to re-syn your m:robe and re add songs.
Or you can try sync on a different computer and resync on your own computer
Aug 12, 2008 | Olympus m:robe MR-500i MP3 Player
Lost my webcam installation cd
sir, i can't find the driver for my web cam Logitech do not know exactly which model, only the serial numbers.
M/N: V-UAL9 Rating: 5V 100mA
P/N: 861154-0000
S/N: LNA42802374
my email address is [email protected]
hope to get the solution soon
Jul 18, 2008 | Logitech Webcam
Windows startup error
I lost my password on windows xp, how can I get back on the administrator screen instead of guest screen.
Feb 17, 2008 | Computers & Internet
Olympus m:robe MR-500i MP3 Player Logo
Top Olympus Audio Players & Recorders Experts
Richard Schabler
KBeaN1
Level 1 Expert
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
