There is power going to the control panel. the lights work.
the green light for the pump is on when you try to turn it off
by pressing it again. It just stays green and the pump remains off
Turned out to be a fuse, contacted the local dealer directly and they said dreammaker has changed vendors on the control box unit and
they have been having problems with the 250V 15Amp fuse.
Suggested that I go to a 20Amp, but that I should contact dreammaker
directly
need more info will pump motor spin freely if not turn by hand remove cover on back of motor sometimes they lock up with power off turn by hand a few times then try with power
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
I would try leaving the TV unplugged for 30 minutes to let the TV reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. I can't say it's 100% the problem because I can't actually look at the tv over the internet. If by chance the TV is still under warranty, go that route. If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
