Question about Numatic Henry Bagged Canister Vacuum
Numatic henry keeps cutting out & plug crackles in the socket!
I've got a numatic henry and yesterday started to experience problems. It was working fine, I left it for a while and then when I switched it onto use it again it would only work for a few seconds then stop. Have changed the 13amp fuse in the plug a couple of times and experienced the same problem. Have now noticed that when the plug is in the socket (and the socket is switched on) I can hear a crackling sound - eek! Any clues what the problem might be?
  • Anonymous Jan 02, 2010
    Problem solved - ish. Appears to be the socket not the hoover! Have just plugged something else into the same socket and heard the same noise. Plugged the henry into another socket and it works fine.
    Glad I heard the noise again before the socket did something horrible to my mobile phone!
Anonymous
    New Friend:
It wasn't the hoover, it was the plug socket!
Posted on Jan 03, 2010
No power, electrical wirring is intact from power plug to switch to pcb
normally with a henry the cable breaks from where it joins the hoover just take apart from hoover end cut about a foot of cable off and then rewire
Feb 09, 2014 | Henry Numatic "" Canister Vacuum
Power switch
here is a video that will give you full instructions how to replace switch
Feb 22, 2013 | Numatics Numatic Hhr200-2 Henry "Hound"...
Henry hoover
Hi it can be the connector at the end of the Henry cable inside the cable rewind unit happened to us!
Nov 14, 2012 | Numatic Henry Bagged Canister Vacuum
Hi, last week I bought a new Henry vacuum with autosave, now the autosave feature is not working. The red indicator light does not light up and the motor does not change speed. Any ideas, other than...
Sadly you need to return to dealer, any problem contact Numatic (www.numatic.com), who supply it with a good 2 year warranty, which the dealer should support. This is a fault I see about 1 in 100, so you are a little unlucky. It will need a new switch and can easily be fitted by the dealer. With Henry's usual life expectancy anything from 5 -20 years it is well worth getting sorted.
Feb 06, 2011 | Numatic Henry Bagged Canister Vacuum
My Henry keeps shorting out? Changed fuse and bag but still wont work?
Most common cause of this problem is a damaged flex. Damage may not be visible externally, but after a lot of bending and pulling the wire inside the flex can break. This usually happens close to the plug, so examine it very carefully for signs of damage (if there has actually been a short circuit, there may be a tiny hole blown in the outer insulation). Unfortunately there is no easy way to locate an internal break without special testing equipment. You can try just cutting off the old plug with about 6 inches of flex, and then fitting a new plug - if that doesn't work you may need professional help. Good luck!
Feb 28, 2010 | Numatic Henry Bagged Canister Vacuum
My henry vac switch is dead.
You will need to remove the top cover of the vaccum by removing the 4 screws underneath.The you need to test with a multimeter if you have 240 volt power to the bottom of the switch. If you haven,t power there you will need to check the plug connection or replace the power lead.
Jan 08, 2010 | Henry Numatic "" Canister Vacuum
Henry Hoover throwing trip switch in house
Sounds more likely to be the switch than the motor, especially if it is the model with the top switch rather than the side "rocker" switch. If you are in the UK, speak to the technical people at www.a1cleaningsupplies.co.uk they can post a replacement. Otherwise outside or even within the UK you can contact the manufacturers technical people. Website is www.numatic.com
May 25, 2009 | Numatic Henry Bagged Canister Vacuum
Numatic Henry Micro HVR-200
motor is over heating. you need to clean bag, filter and hose first then re test
Aug 21, 2008 | Numatic Henry Bagged Canister Vacuum
Numatic Henry Bagged Canister Vacuum Logo
999 people viewed this question
Top Numatic Vacuums Experts
Marvin
Marvin
Are you a Numatic Vacuum Expert? Answer questions, earn points and help others
