Question about Oster 12-Bottle Wine Cellar - Black
Digital temperature display is missing part of the
I have an Oster Wine Chiller and the digital temperature display is missing part of the numbers. The fan works and the cooler is getting chilled.
  • Anonymous Mar 20, 2014
    Temperature display just has lines - so can't tell what it's set on
Jeremy Reddick
    President:
  • 1,902 Answers
You are going to have to replace the display. Easy fix even if you are not very familiar with this system
Posted on Jan 02, 2010
Testimonial: "Thank you for the quick response!!!!"
  • Vette4me
    Vette4me Jan 14, 2011
    Where do you get the display? I have checked several sources
Jason Stock
    New Friend:
How do I remove the bezel from the digital display?
Posted on Jun 11, 2015
How can i adjust the temperature of my 24 bottle dual zone wine refrigerator? I want to increase the internal temperature.
Brand? Model?
There should be a display (digital) at top of chiller or at least one or two dials at the rear of chiller cabin near the sides. You should be able to set each area by adjusting dial(s). Though there are some units that have only one dial as with the Sears brand that will presume you load the wine bottles at the top or bottom of box.
Aloha, ukeboy57
Jun 04, 2018 | Furniture
Can anyone direct me to an operating manual for the Brandt Wine Chiller?
Search Results
    Download brandt wine chiller manual - Google Docs
    https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesLooking for brandt wine chiller manual? Download brandt wine chiller manual.brandt wine chiller manual. User Manuals, Instructions and Guides.We have that ...
    brandt manual Refrigerators Questions & Answers - Fixya
    www.fixya.com > Forum > Tags > brandt manual
    On my Brandt wine cooler at the top is an adjustment control for temperature. ... is amanual for this refrigerator LG top mount ice box service manual Maytag ...
    Free Refrigerator User Manuals ' ManualsOnline.com
Dec 14, 2015 | Refrigerators
Not colling
Check the back to see if the compressor is running or just really hot. If it is not running it could be a thermostat issue, but if it is hot and not running, that means your compressor has problems and will need to be replaced.
Apr 07, 2014 | Whirlpool 22" Dual Zone 38 Bottle Wine...
Hi, I have a WCR524SDZD wine chiller and the fan has started to make noises, and also the temperatures seem to not drop to the temperatures we expect. Where can I get a new fan? or parts for this...
your unit uses a generic fan motor that a lot of refrigerators ect.. use. If you take the fan to a local shop that sells refigerators they will match up one for you. Avanti's phone number is 1 800 220 5570. good luck
Aug 11, 2010 | Avanti WCR524SDZD Wine Cooler
Wine cooler does not get cool - fans do not run the light and temperature display do work
if you hear the compressor tun on but not the fan, replace the fan and you may have to defrost the evaporator coils. if the compressor does not turn on either, it's the thermostat, the defrost timer, or a relay on the main board.
Nov 12, 2009 | Oster 12-Bottle Wine Cellar - Black
Eurocave digital thermometer
The digital temperature display on the EuroCave has a small lithium battery that can be replaced by removing the bezel around the display. This was all that was needed to solve the problem.
Jan 22, 2009 | EuroCave Comfort 260 Collector's Package...
Temp too high
lamgrimes9,
Welcome to Fizya.,
You said, your Oster wine refrig won't lower its temperature below 76 degrees. I have it for about 5 months, and it worked fine all this time with a setting of 50 degrees. Now it refuses to lower its temp. It reverts back to 76 everytime. Can someone give me any ideas about what is wrong? FYI Mine did not come with an owner's manual.
Sounds like the Thermostat is bad.
http://www.oster.com/CustService.aspx?content=manual
The tel # in your Oster Manual is a recording and will not help you!
But New appliances are under Factory warranty and are fixed or replaced no cost to the customer!you are under
http://www.oster.com/CustService.aspx?content=center
Let me know how it goes.
Huuum
Please leave a rating.
Oct 05, 2008 | Oster 12-Bottle Wine Cellar - Black
Oster wine cooler (peltier diode)
I called the contact in one post below, and he was VERY helpful. Took all my info, submitted to the division handling this and they overnighted me a check for the entire amount plus tax for the wine cooler to me! Call Jason!
Jason's contact info is:
Jarden Consumer Solutions
2381 Executive Center Drive
Boca Raton, FL 33431
(561) 912-4100
Jun 25, 2008 | Refrigerators
Oster 12-Bottle Wine Cellar - Black Logo
1,260 people viewed this question
Top Oster Furniture Experts
Tom Chichester
ray gallant
Are you an Oster Furniture Expert? Answer questions, earn points and help others
