HP Compaq FS 7550 17" CRT Monitor Logo
Posted on Jan 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The monitor screen is turned side way--I have to tilt my head to read the screen, and I am not able to use my mouse to click any icon. Please help.
Anonymous
Level 2:
  • Expert 51 Answers
  • Posted on Jan 05, 2010
Anonymous
Expert
Level 2:
Answers
51
Questions
0
Helped
31856
Points
146
Use CTRL +ALT+ (Arrow keys)to rotate the screen.
How to change orientation of monitor
I'm a little unclear of what you are asking.
1) Screen has turned on monitor?
Press the CTRL key, and ALT key down at the same time.
Now tap on the Left Side Arrow key, until the screen is oriented correctly again.
2) Screen on monitor has shifted left, right, top, or bottom?
Use the controls on the monitor to set it correctly again.
3) Using dual monitors?
Right-click on an empty space on your desktop screen.
Left-click on Properties at the bottom of the list.
Left-click on Settings.
The monitor 1 icon is supposed to be your Primary monitor.
The monitor 2 icon is the Secondary monitor.
Ordinarily the Primary monitor is on the LEFT side, and the Secondary monitor is on the RIGHT side.
Just as shown in the Settings window.
If you wish to move a monitor to the other side, go to the monitor icon you wish to move.
Put your mouse cursor on the monitor icon you wish to move.
Left-click, and hold the left mouse button down.
Now drag the monitor icon you wish to move, to the other side.
Not doing it for you?
Then post in a Comment with more exacting information, as what it is that you wish to do.
Regards,
joecoolvette
5helpful
2answers
Can i connect two monitors to a nvidia geforce 315 card so as too use two monitors
hi,
yes the 315 desktop card does have multi monitor support. you may however need an adapter for one monitor as it only has one dvi ,one hdmi and one vga.
so you can hook up any 2 as a combination but they have different plug configurations to do this
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
I have a Dell Inspiron 531S, I have both two different monitor slot, does my PC support dual monitor systems?
Yes.
The area on the back of the computer, that has two ports to connect a monitor, is a Graphics Card.
It is a PCI-Express graphics card, and is plugged into a PCI-Express x16 slot on the motherboard.
(Expansion Slot)
It has a blue VGA port, white DVI port, and black S-Video port.
The area on the upper left with a blue outline around a VGA port, is a VGA port connected directly to the motherboard. It is Integrated Graphics.
You CANNOT use Integrated Graphics, and a graphics card at the same time.
It's either use the Integrated Graphics VGA port, OR use the graphics port/s on the graphics card.
BIOS will Not support using both Integrated Graphics, and a graphics card.
HOWEVER, you can use the VGA port, and the DVI port when using two monitors.
You will be only using just the graphics card.
Example of a VGA port, (Connector), and VGA cable,
http://en.wikipedia.org/wiki/VGA_connector
Example of a DVI port, and DVI cable,
http://en.wikipedia.org/wiki/DVI_connector
1) Whatever monitor you have that has a VGA cable, plug it into the blue VGA port on the graphics card.
(There are VGA monitors {CRT} that resemble a small TV. VGA cable is usually attached.
There are also LCD flat screens that have a VGA connector, for a VGA cable, and may also have both a VGA, and a DVI connector.
To digress for a moment;
VGA is Analog. It uses an Analog video signal.
DVI is digital. It uses a Digital video signal.
A computer naturally puts out a digital video signal. This digital signal has to be converted by the computer, into analog for an analog monitor. This slows the graphics process down. This is one reason it is best to use digital )
2) Plug a monitor with a DVI cable into the white DVI port on the graphics card.
3) Turn the monitors on.
4) Turn the Inspiron 531s on.
5) When Windows has loaded, right-click on an empty area of your desktop computer screen.
Now left-click on Properties at the bottom of the list.
Left-click on the Settings tab.
6) You are now looking at a small window that has two monitor icons in it.
Monitor 1 icon, and monitor 2 icon.
Monitor 1 icon is your Primary Display.
Monitor 2 icon will be for the Secondary Display you are adding.
Note how monitor 1 icon is sitting to the Left, and monitor icon 2 is sitting to the Right.
This is how your monitors are supposed to be arranged on your computer desk.
If the second monitor is on the Left on your computer desk, you need to move the icons around.
Move monitor 2 icon to the Left.
Left-click on the icon, hold the left mouse key down, and drag the monitor 2 icon over to the left side of monitor 1 icon. (All the way over, or it will snap back to where it was)
It may matter to you how your monitors are arranged. It may not. Once you read the following it may help you decide.
7) Left-click on monitor icon 2 if you have not already done so.
Go down to where it states, "Extend my Windows desktop onto this monitor"
8) Left-click once in the empty square, to the left of Extend my Windows desktop onto this monitor.
9) Now left-click on Apply at the bottom Right corner.
10) Finally left-click on OK at the bottom Left corner.
You should now see your desktop screen on both monitors.
When using the internet on both monitors, you have to drag the screen from the Primary monitor to the Secondary monitor.
Go to the left side of the screen. Left-click right on the edge of the blue frame. Hold the left mouse key down after you click, and drag the screen across to the left.
Doesn't work?
Go to the right side, click on the blue frame, and drag the screen to the right.
This is why it may matter how the monitors are arranged on your computer desk.
It's kind of eerie your first time dragging the screen across.
You will also find out why it is best to use two similar monitors, when using dual monitors. The pixel resolution is different for both monitors, if they are different from each other.
For additional questions please post in a Comment.
Regards,
joecoolvette
Just to add:
http://support.dell.com/support/edocs/systems/inspd531/en/OM/appendix.htm
2helpful
2answers
Hello! I have a processor intel pentium dual cpu e2160 @1.80 Ghz and for display a graphic card NVidia GeForce 7300SE/7200 GS, DAC Type Integrated RAMDAC 512 mb. I use my VGA monitor connected to the...
Hello ghinea18, sorry you can't do that because this will cause hardware conflict, that's why motherboard bios automatically disable integrated graphics if you install video card using pci express x16 slot - Nvidia GeForce 7300SE. do you know if your video card has dual vga or dual dvi connection?
You can try dual display, im not sure if this card supports dual monitors because nvidia online specs does not show full specs on 7300se series. \
Good Luck!
Print is fading out. some times it is perfect but most print from my HP photo smart 7760 is a portion clear and gradual lightening to smudge like...
Hi Good day!!! Try to clean your print head
Please follow this step:
1. Turn on the computer and monitor. If using a Windows-based computer, click the "Start" button on the toolbar at the bottom of the monitor screen.
2. Move to "Settings," then "Control panel."
3. In "Control panel," look for "Printers and other hardware." Click on it. Inside this dialog box, you should now click on "Printers and faxes."
4. In the "Printers and faxes" dialog box, select the HP printer icon.
5. Using the right mouse button, click on the "HP printer" icon. At the bottom of the list, click on "Properties."
6. You should see seven tabs in this dialog box. To clean the printer heads, click on the "Services" tab. Under this tab, select "Align the printer cartridges" and "Clean the printer cartridges." For now, click on "Clean printer cartridges."
7. A new dialog box should appear, then click on the "Clean" button. The cleaning will now begin for the printer heads. This only takes about two minutes to complete. If you think your printer heads have not be cleaned well enough, do another test until the printer functions as it should.
8. Cleaning printer heads is something that should be done on a regular basis. Cleaning the printer heads will keep the printer from being ruined and causing unnecessary headaches.
Thank you for using FixYa
Please accept if my solution helps you.
1helpful
TRYING TO CONNECT TWO MONITORS FOR EXTENDING USE
1) You have to have a graphics card with two monitor ports.
You Cannot use one port on a graphics card, and the VGA, or DVI port on the motherboard of the computer.
BIOS will only let you use the graphics card, or the Integrated Graphics.
2) Using a 'splitter' cable results in very bad graphics on two monitors, or no graphics at all.
3) With a graphics card installed that has two monitor ports on it, connect the monitors to the graphics card.
[ The graphics card can have a VGA port, and a DVI port. Or the graphics card can have two DVI ports.
VGA = Video Graphics Array
Photo of a VGA port,
http://en.wikipedia.org/wiki/File:SVGA_port.jpg
Photo of a VGA cable,
http://en.wikipedia.org/wiki/File:Vga-cable.jpg
DVI = Digital Visual Interface
Information about DVI showing a DVI cable, and connector examples for the DVI port on a graphics card,
http://en.wikipedia.org/wiki/Digital_Visual_Interface ]
4) Turn the two monitors on once they are connected to the graphics card.
Turn on the computer.
5) Windows loaded, right-click on an empty area of the desktop screen.
6) In the list go to the bottom, and click on Properties
7) Click on the Settings tab.
8) You will see two monitor icons.
One icon has a square with a 1 in it.
The other icon has a square with a 2 in it.
The 1 monitor icon is used to represent your Primary monitor.
The one you have been using.
As you can see the 1 monitor icon is sitting to the Left.
This is how your Primary monitor should be sitting on your computer desk.
The 2 monitor icon is used to represent your Secondary monitor.
The one you are going to add.
As you can see the 2 monitor icon is sitting to the Right.
This is how your Secondary monitor should be sitting on your computer desk.
Left-click on the 2 monitor icon.
Go below in the Display Properties window, and view where it states -
There is an empty square to the left of it.
Left-click in the empty square.
Now go below to the Right, and click on - Apply
Finally go below to the Left, and click on - OK
Your desktop screen will now be on your Secondary monitor.
Whatever is on your Primary monitor, has to be drug over to the Secondary monitor, when you are on the internet, or a program. (Such as a game)
Go to the blue frame on the Left side of the Windows screen.
When your cursor turns into a double-headed arrow STOP.
You'll find it's a little tricky your first time, keeping your cursor into the position where it turns into a double-headed arrow.
With the cursor in a double-headed arrow, press the left mouse button down, hold it down.
Drag the monitor screen to the Left.
Keep dragging until the window on your Primary monitor is on your Secondary monitor.
It's helpful you'll find to have two of the same size monitors.
I have found occasion where when using the internet on two monitors, that I had to Restore Down the screen, THEN drag it over to the Secondary monitor screen.
(Icons at the top right of the monitor screen.
Minimize ( - ), .......Restore Down/Maximize, ...........Red X
Then I Maximized the screen
For further questions please state in a Comment.
(Believe upper right of your page. - Comment
My laptop working area has turn to the right, actual laying to the side, which means I have to tilt my head to read on the screen. Please help
Right click on an empty spot of the desktop away from the icons, scroll down the drop down menu until you see something like Nvidia control panel or ATI control panel. If you don't see any of those then go to the bottom and choose properties. If you have the control panel up, look about halfway down for the text "Screen orientation" choose "landscape" or "0" degrees. If you can only bring up the properties menu, choose "display settings" look for "Orientation" and then choose Landscape from the drop down menu.
2helpful
3answers
How can we connect two moniters to one cpu
To have and use 2 monitors at the same time, you need a video card with a dual VGA outputs.
To use 1 monitor at the time you can buy a VGA switcher, to switch between the 2 monitors.
Best of Luck
Sabre
We have Dell OptiplexGX745 smallform factor desktop computers that we need to run two monitors.
If your Dell Optiplex GX745 came with the ATI Radeon X1300 graphics card, that has One - DVI graphics port, and One - VGA graphics port, it's no problem.
This link shows an ATI Radeon X1300, and the two above mentioned graphics ports,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5550932&CatId=28
(Please scroll down to the larger photos for more detail.
The Radeon X1300 graphics card in your computer, is a Low Profile graphics card. It will not look exactly like the one shown.
Low Profile means shorter in height. Your graphics card is shorter in height, in order to fit in your SFF computer case. {Small Form Factor}
The longer white connector shown on the left side of the view, is a DVI port. (Technically it's a Dual DVI port)
The shorter blue connector shown on the right side of the view, is the VGA port.
1) If one of your monitors has a DVI connector plug, simply plug it into the DVI port.
If the other monitor also has a DVI connector plug, you will need an adapter to plug it into the VGA port.
2) If both of your monitors have a VGA connector plug, one will plug into the VGA port on the graphics card.
The other will need an adapter to plug into the DVI port, on the graphics card.
This link shows an adapter for connecting a monitor with a DVI connector, to the VGA port on a graphics card,
http://www.directron.com/dviadapter.html
The adapter to connect a monitor with a VGA connector, to a DVI port on the graphics card is opposite of this.
[ I have found them at Radio Shack.
This = Expensive! $14.99
Not advertising for Radio Shack, or the above website in the link]
NOTE*
Use care when selecting the adapter you need.
A monitor with a VGA cable connector has the Male pins.
Your adapter must have the VGA Female sockets.
The DVI side of the adapter must have the Male pins.
It goes into the Female socket holes on the graphics card.
Same with a monitor that has a DVI cable connector.
The adapter must have Female DVI socket holes.
The other side will have Male VGA pins.
If your ATI Radeon X1300 only has One - graphics port, I Do Not advise using a splitter.
This is an adapter cable that has a connector on one end, and splits into two cables.
The graphics quality will be poor.
If you have No graphics card the situation is worse. This is Onboard, or Integrated Graphics.
(OnBoard. On the motherboard)
Using a splitter cable will result in very poor graphics.
How to tell if your Optiplex GX745 only has Integrated Graphics?
Look at the back of the computer. Come down from the audio ports. (Green and Blue)
Look under the USB ports.
The Blue VGA port is the Integrated Graphics port.
If you have an ATI Radeon X1300 graphics card, you will see a blue VGA port in an adjacent slot, also.
(Your computer can have Integrated Graphics, and a graphics card.
You CANNOT use the Integrated Graphics port, and a graphics port on a graphics card, At The Same Time!
It will Not work)
Once the two monitors are attached.
1) Turn both monitors on.
2) Turn the computer on, let Windows load
3) After Windows has loaded, Right-click on any empty area of the desktop screen.
4) Go to the bottom of the drop down menu, and Left-click on Properties
5) There are tabs across the top. Left-click on the
Settings tab.
6) You will see two rectangular icons. These icons represent monitors.
The one on the left side with the white border around it, is your Primary monitor. The main monitor you have always had.
The grayed out icon on the right side represents a Secondary monitor. This is for the second monitor you plugged in.
Note how the two monitor icons are sitting.
Primary on the left, Secondary on the right.
This is how your monitors should be sitting.
If it is Not, left-click on the Secondary monitor icon. Hold the left mouse button down, and drag it over to the left.
Now scroll down this window with your eyes.
Under the resolution settings you will see -
There is a square box to the left of it.
Left-click in the square box. Go below to the right, and left-click on Apply.
Now go to the left, and click on OK.
Your monitors will now both be showing your desktop screen.
[Note* When doing this procedure, you have clicked on the Secondary monitor icon. Clicking on the icon activates it]
When you open the internet, or have a program going.
Go to the right side of the screen to the blue border,
of the Primary monitor.
When the mouse cursor turns into a double-headed arrow, hold the left mouse button down, and drag the screen to the right.
(You will note that the mouse cursor changes quite easily. It has to be double-headed in order for this to work)
If this direction does not work, go to the left side of the screen, drag to the left.
(You have to drag in the direction your monitors are actually sitting, in relation to each other)
Need some clarification, or have further questions? Click on Comment.
1helpful
2answers
How to adjust screen resolution with external monitor/hp pavillion dv 2000 laptop
1.Right-click on an empty area of your desktop screen
2.Left-click on Properties at the bottom of the drop down list
3.Left-click on Settings in Display Properties window.
4.Left-click on the 1 monitor icon to adjust the screen resolution for the HP dv2000 LCD screen.
Left-click on the 2 monitor icon to adjust the screen resolution for the external monitor.
5.Go down to where you see the heading - Screen Resolution, and the slider underneath the heading.
Left-click right on the slider, hold the mouse button down, and slide to the Right to increase resolution, to the Left to decrease resolution.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
