Amana AFD2535FES Stainless Steel Bottom Freezer French Door Refrigerator Logo
Anonymous Posted on Jan 02, 2010
AFD253DEW has stopped cooling - Amana AFD2535FES Stainless Steel Bottom Freezer French Door Refrigerator
Anonymous
Level 1:
  • Contributor 35 Answers
  • Posted on Jan 02, 2010
Anonymous
Contributor
Level 1:
Answers
35
Questions
0
Helped
10748
Points
63
Check cold control or defrost timer. then check compessor
Testimonial: "Thanks "
Breezaire wksl4000 fan stops turning and unit stops cooling after about 20 minutes. Fan will start and fun but then stops. Any ideas?
This is likely to be caused by the start/run capacitor on the fan. Call for service, you don't want your valuable wine collection mistreated!
https://www.google.com/search?q=Breezaire+Wine+Cellar+Cooling+Unit+service
Wine cooler cools but has a very loud, too loud to ignore, whirring sound when it is in cooling mode. Any ideas?
And when the wine is cooled ... the noise stops?
It's like a refrigerator ... it only operates when it it is reducing temperatures. Once things have cooled, the system cuts out.
If your wine cooler stops making a noise when the wine is cooled ..ok.
LG Express Cool Turbo GR T542G Stopped cooling
it should run when the comp is on and the unit is calling for cooling, you most likely need a new fan for your unit.
1helpful
My ac in my dodge truck only works when I am driving, but when I come to a stop it will stop blowing?
Stop blowing cool or stop blowing anr air through the vents??? If it stops blowing cool air, check if the condenser fan is running (it should be)( on drivers side under hood, looks like a small radiator) if not take a water hose and deluge the condenser with water, if it then cools, you will need a new condenser fan assembly.
Unit cools for a few minutes then stops cooling. Even fan stops blowing air but the unit remains 'on'
unit may be short of gas. will run for a few mins before low pressure switch turns the compressor off. you will need to get an engineer to check gas pressure
1helpful
The compressor stops working. I parked the car for a week and when I came back from out of town it wasn't cooling. I took it to the dealership, they said the relay was popped out o_O. popped it in, started...
sounds like they cant find the problem, i dont think an 03 would have that kind of wiring problem, i think there guessing, could be a bad compressor, but hard to say without checking it . good luck, maybe its time for a 2nd shop to look at it.
Freezer and refrigerator doesn't cool properly
Sounds like a main control board bad . A model number would help .
3helpful
Won't Stop Cooling
thermostat is stuck. try buying a water cooler control from a local supply house.
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
