Proscan 42LA45H 42 in. LCD TV Logo
Question about Proscan 42LA45H 42 in. LCD TV
Our proscan 1080p wont turn on with the remote. Any ideas??
Posted by mandalubbw on
Anonymous
    New Friend:
  • 21 Answers
Dead batteries in the remote ? Is it a universal remote correct component selected ? Will the set turn on at the TV power button ? Hard to say with such a vague description. These should give you more information to interject.
Posted on Jan 02, 2010
I have to take the remote right up to the blue light on the TV to get it to change the source options
wipe lenses of remote with clean cloth, weak batteries, change batteries , faulty remote replace
Need remote code for proscan led tv
For which remote exactly? Each manufacturer of programmable/learning remotes has their own code base and unique numbers for each code.
Asking for a code is like asking for the postcode/zip code of Acacia Avenue but without specifying the city and district.
Proscan manufacturer
Place your phone on picture mode. place it over the remote infra red section the press any button on the remote. If you see a red signal then the remote is good. If not, you need a new remote.
If the remote is good then your sensor on your t.v. is bad. You will need it replaced.
2answers
I have a Proscan 40 inch 1080P LCDTV (40LD45Q), but when I connect my computer to it, (GTX 260) with DVI-HDMI cable, it says the native resolution is 1366x768. Is Proscan lying that this TV is 1080P?
You can attempt to force 1080p to the TV by unchecking the box "hide modes this monitor cannot display" in the display adapter propteries, then try to select 1920 by 1080p, 60hz, 32 bit color, and see what happens. Post back what your findings are.
1helpful
We have a proscan 1080P -- our little girl got ahold of the remote and now I think it is not programmed. It isn't doing anything on our tv. I can change the picture -- like zoom, wide, normal but it won't...
This is an orignial remote to the tv?Not a universal remote wright?Yes,it can't be reprograms,only universal remote can be reprogramed,by re entering the tv codes.Take the battery out like 24 hrs put it back in the remote should reset itself.Should work now,not then the remote CPU is dead.Sorry the remote is junk now.Try webste like Remotes.com to buy an exact to the original remote.
My proscan tv is on 420p setting. how do i set it to 1080p?
You do not set the resolution at the TV, the TV will display what video resolution you feed it, I also doubt that the your 19" can do 1080P.
4helpful
How to activate "closed captioning" for a Proscan Full HD 1080P
Comcast's remote has nothing to do with closed captioning. It's on your tv remote. First, the tv has to be capable of handling closed captioning, and your's is- and second, the program must have closed captioning provided- current programs do, some older shows do not support closed captioning. Recheck your remote, and if necessary- look at the setup instructions that came with the TV- they should also be posted online at the Proscan support site.
2answers
Remote not working
If this TV came with an universal remote, try pressing the TV key. Sometimes it works.
If that did not work any other RCA, GE, Proscan universal should work.
Top Proscan Televison & Video Experts
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
