Question about Protron PLTV-32 Television
The tv screen does not turn on tv srceen blandk , use to have to wait for the light to turn on, then hit the switch on as soon as the light turns on, if not right away then the picture does not turn on at all.the tv is a prima LCD flat screen
Posted by Peter Tomson on
Anonymous
    New Friend:
Sell it
Posted on Jan 02, 2010
My olevia LT23HVX does not power on
Try unplugging and replugging after waiting.
Jun 13, 2008 | Olevia LT23HVX 23 in. LCD Television
I have an Insignia NS-LCD37 was working perfectly fine, all of a sudden the TV went black, I would turn the TV on and you would get the
Most likely you have a fault in the back light circuit. To verify this, turn on the set, when the screen goes black, take a bright flashlight and shine it on the screen. It may be easier to dim the lights in the room so that you can see the faint image on the screen. If you see the faint image, you indeed have a back light problem. You will need to get a diagnoses performed on the set to track down the problem
Nov 22, 2012 | Insignia NS-LCD37 37 in. LCD TV
What is the remote code for panasonic TC-L32C3 for the time warner control?
turn tv on
on remote
1. hit tv
2. hold down setup till it blinks twice(tv button light)
3.then press 991 wait till it blinks (tv button light)
4.press channel up slowly until tv turns off
5. once it turns off hit setup again
6. press the tv then power button and then see if tv turns on if not then you just missed the code(repeat)
Aug 28, 2011 | Panasonic TCL32C3 TV
My GVA LCD flat screen TV switches itself off as
My flat screen will not turn on the green light flashes for a while then stops
Feb 23, 2010 | Televison & Video
TV screen turned on for only 10-15 secs then self turn off, followed soon after by the tv power another 10-15 seconds later. if i try this a few times screen wont light up at all.Is it the TV Lamp?
1) Can be dust do a good clean
2)Check for the fuse and change it if needed.
3) Capacitor needs to be changed, you'll have to findout which one.
Hope it helps, good luck
May 19, 2009 | LG RU-52SZ51D 52" Rear Projection...
Ipod nano 4th generation 8gb purple wont turn off
Try holding the Play/Pause button down for a few seconds. Like maybe 5 or so, thats how my 3rd gen turns off.
Jan 28, 2009 | Apple iPod nano 4th Generation
Philips 42PF9956/37 Plasma TV - Looking for y sustain board
it isnt the Y-SUS board, it is the Power supply, iv fixed this exact problem twice in the last month, try turning the tv on, and when it turns green, unplug it real fast, while light is still green, after 15 seconds plug it back in, then hit the power button, if it dont come on, hit the power button again, this time, as soon as it turns off, hit the power button again to turn back on, sometimes you can trick the tv and it will turn on, at least i was able to do it, and once it comes on, it should work fine, untill you turn it off again.
Jan 10, 2009 | Philips 42PF9431D/37 TV
Cannnot control my new emerson tv using my COMCAST controler. model LC320em9 what code do i need to use to make this work.
you need to hit the tv button, then hold down the setup untill the lights plink twice, then hit 991, then power, if it doesnt turn off, hit tv again, then the power again, keep doing that untill the tv turns off, as soon at it turns off, you need to hit the set up button again, that locks in the code, then you should be able to turn it back on with the remote
Jan 08, 2009 | Televison & Video
Protron PLTV-32 Television Logo
282 people viewed this question
Top Protron Televison & Video Experts
Ekse
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
