I am afraid I fried my Tom Tom. I plugged my car charger into the back of the Tom Tom and two wires got crossed. Smoke came from the connection so I immediately unplugged it. The Tom Tom eventually turned on, but shut off after the battery ran down. A local store (where I bought it) said I may have fried the charger or the inside of the Tom Tom. When I plug my car charger into the back it indicates it is charging, but it will not turn on. HELP!
Try a reset first, i will assume you cant do this, get a clip or pin switch off the unit and remove the sd card, then push the tool into the small reset hole underneath and hold for 15 seconds, then turn your unit back on and replace the sd card, it should then work if not it could be the battery has worn out as they are attached to the charger all the time when driving, hope this helps
