Analog regular channel TV was turned off mid 2009. You need a digital channel convertor box to receive the new digital channels... The analog ones went bye, bye in the USA. Without the box you will just get noise.
Wasn't clear that pix was fine... I misunderstood that...
You said you have a digital cable box... I ASSUME that means that you are connected to cable.
IF SO, the problem is LIKELY with the head end of your cable provider. You should first report it to them... they MAY already know of the problem.
With no signal into your TV the normal thing would be noise, so when you disconnect, only noise would be expected.
If you have a DVD player or VCR to test with, if your TV works with that, the problem is the cable box or the cable.
I have the a digital cable box, picture is fine but the sound is just white noise at full volume, no mute, no volume control.
