Question about RCA Universal Remote Control
I cant to program my cable channels with my univ remot sony tv
The remote will turn the sony tv off/on but the cable channels are not working and the menu operation is not working properly so that i cam set the channels
Posted by willisone on
Anonymous
    New Friend:
I like the Logitech Universal Remotes. You hook it up to your computer and load software and enter model numbers and it programs it automatically. ( a little expensive, but easy)
Posted on Jan 06, 2010
Julio Hernandez
  • 616 Answers
Do it manually, front panel controls, or buy sony brand universal at wallymart
Posted on Jan 02, 2010
Is there any way to get my tv channel back on 4 with no remote?
Try after amke a factory reset to your tV. Normally, aits remote control is needed to make it channel-4.
Apr 29, 2012 | Televison & Video
My tv's channels are only up to ch 35, and we have cable tv connection. I cant utilize my cable connection cause my tv's only programmed up to 35. do we have a way to program it to go up to more than 35?...
I assume you have analog cable TV service and no cable box. Press MENU button on your TV remote. Go over to CHANNEL SETUP. There are four arrow buttons and a button in the middle of the arrow buttons on the TV remote control. Use these arrow buttons to go up, down, left and right. Use the button in the center to select. TV On-screen menu has Video, then Audio, then Channel Setup.
Cable can be set to ON or OFF, you want to set it ON to get cable channels.
Go down to AUTO PROGRAM and select it, press button in the center of arrow keys.
A short delay while available channels are searched so be patient. After Auto Program finishes, press MENU to exit. You can perform Auto Program whenever required.
You can also add or skip channels manually. You will discover more options in the TVs menus.
Feb 24, 2011 | Sony FD Trinitron WEGA KV-36FS320 36" TV
I got a remote control for my tv cant change channel
Did you attempt to program the remote with the tv? Is it a universal remote? If so, most remotes come with a list of codes to try with most tv's. Does the volume work? Can you type in a channel direct... pressing 5 for example? If those work but not the up/down channel, the remotes faulty. Or is it set to tv or cable?
Sep 28, 2010 | RCA Universal Remote Control
Cannot program Emerson Jumbo Univ remote to DirectTV
Try this: Press and hold the TV Power button and the Dirctv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
Dec 27, 2008 | Tivo DirectTV Remote Remote Control
Cant turn the tv to channel 3
Go to the Menu setting, and do a auto channel scan, it will automatically program it to NOT skip 3.
Nov 25, 2008 | RCA Universal Remote 3 Device Remote...
Gfm tv universal remote code
Use the code for the sylvania tv. It worked for me!
Apr 30, 2008 | Televison & Video
How to use Toshiba 32D46 32" TV with Comcast 3 in 1 Universal Remote Control
Most univ. remotes have a search mode if code entry won't work-
Do you have the comcast instructions ? Something like.....
1) Tv power on
2) Push set-up or program on remote
3)Touch tv button on remote
4) Point remote at TV and push power off. Repeat until TV turns off.............then
5)Push enter to save....
Hope I helped you........T.
Nov 07, 2007 | Toshiba 32D46 32" TV
Televison & Video Logo
169 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
