Question about Lexmark X7170 All-In-One InkJet Printer
I can't get my laptop to communicate through wireless router to printer.... We have done all the installs but when I try to print, the computer says, can't communicate with printer....
Posted by jack_ducharm on
5 Related Answers
Anonymous
SOURCE: Lexmark X 1270 Can not Print
try reinstalling the driver
Posted on Dec 20, 2007
HisChild
SOURCE: Lexmark X4850 wireless set-up
I have a Lexmark X4850, every time I print a job it prints a blank page first then the document. I have tried to tell it to print 1-1 or 1-3 but it continues to print that blank page first. any suggestions.
Posted on May 08, 2008
rjwharris
Harris
  • 102 Answers
SOURCE: The printer will not communicate with my computer
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Posted on Feb 21, 2009
Anonymous
SOURCE: Lexmark X8350 "communication not available"
I fixed this by completely uninstalling the Lexmark software, then unplugging the USB and restarting. I then installed the new Lexmark software that I downloaded from their site, make sure not to plug the USB back in until it told me to. It then detected the printer properly and started working.
Posted on Jun 03, 2009
Anonymous
SOURCE: I have a Lexmark Prevail P705 wireless all-in-one
You have free tech support with Lexmark for this printer. You might try contacting them. Secondarily, you could try resetting the factory defaults from the front screen of the printer, and removing the power block (the power cord is connected to it) then reinserting it.
You can access driver downloads directly at the Lexmark support site. I know that during my setup of a P705 that it would not automatically download the updates.
Posted on May 21, 2010
What do I need to make my printer wireless?
You need 1) a wireless router with a USB port that supports the HP OfficeJet printer. 2) The software for your router to run a printer on the USB port. Obviously, you will need a USB A/B male end cable.Note: the scan features of the all-in-one may not work unless the printer is directly connected to the computer. Bi-directional communication is required for scanning and the router software may not support this completely.
Check the list of supported printers closely for older routers. I have a Cisco Linksys E4200 v.2. This router supports all the HP printers that I use.
If this is a new installation of the printer, first install the printer on the computer. If you have Windows 7, just connect the printer to the USB port on the laptop. This will install the OS drivers for the printer. (For Windows XP, go to the HP site and get the full software.)
Next install the wireless router between your modem and computer and set that up. (If you have DHCP (dynamic address allocation), it should be automatic. Otherwise follow the directions.) Next install the router software (for my router, it was Cisco Connect).
My next step was to launch the Cisco Connect program and connect the printer directly to the USB port on the router. In Cisco Connect, choose add a printer and find the printer connected to the router. Print a test page. (At times, I've had to reset the port that the printer is on in the Windows Control Panel Printer Properties. (For the Cisco Connect, the printer is on the DOT4 port.)
Other routers will be set up somewhat differently.
Another option is to have the printer connected to a desktop and then make it a shared printer with the wireless router communicating between the laptop and the desktop. This makes the desktop the print server, so it needs to be on when you want to print. If you have several computers with Windows, this can fairly easy to set up. Make sure that the computers are in the same Workgroup (XP) or Homegroup (Win7). Enable sharing and you are done.
I hope this helps.
(who has a OJ 7000 (with ethernet port) and a LJ1320 (USB) connected to the router. Three computers talk to these printers with the laptop on the wireless network. On an older router that didn't support the printers, the laptop was the server for a previous OfficeJet and one of the desktops was the server for the LaserJet.)
Aug 27, 2012 | HP OfficeJet 6110 All-In-One InkJet...
I have a T-41 IBM Thinkpad trying to install a wireless printer. The laptop cannot find the Brother wireless printer!
Sometimes during the installation of some wireless products, especially printers, you will have to configure the connection by first connecting the printer via USB, then after removing the USB the wireless will be allowed to be found...
Aug 26, 2011 | IBM ThinkPad T41 Notebook
Need my laptop to communicate wireless to printer
If the printer does not have a built-in network card/print server then there is a couple of ways to do this.
If you have a desktop computer connected to the wireless router with a LAN cable, then connect the printer to the desktop computer and make this printer a shared printer on your network. This means that the desktop computer and printer needs to be on when you want to print from the laptop.
The other way is to purchase a print server, connect the printer to the print server and connect the print server with a LAN cable to the Wireless router.
If you don't have sufficient network ports on the wireless router then you need to purchase a hub. Then connect the hub and wireless router with a LAN cable and then the print server to the hub and other computers to the hub.
Setting up the wireless printing will depend upon which method you want to adopt and I can advise you when further when you are ready.
Aug 02, 2009 | HP Photosmart 3310 Printer
Connecting new linksys n to our brother mfc685cw wireless printer. Printer will not read new linksys n router
For isolation purposes, you may want to test the printer through the Linksys router via Ethernet cable and see if you can print if it is wired to the router. From there, configure the wireless printer to match the settings on your Linksys router. Once done, try printing again wirelessly.
Tips:
1. Make sure that they are on the same LAN segment. By default the IP address of the Linksys router is 192.168.1.1. so you may want to configure your printer using 192.168.1.2 for them to communicate.
2. Make sure that the wireless settings on the Linksys router match the wireless settings on your wireless printer. Check the SSID/Wireless Network Name and Wireless Security. All wireless settings should be the same for them to communicate wirelessly.
Jul 12, 2009 | Linksys WRT160N Wireless Router
Dell 3300 adapter
Let me recap, just one more time.
Your wireless router,
You updated the firmware(most have out dated firmware from sitting in the warehouse)
Broadcast SSID
Using WPA-PSK(TKIP) Security
Mixed mode(b and g, n if available) This is needed for wireless devices to work properly.
Channels 1, 6 or 11. These channels are the channels most wireless devices work on the best(I use channel 11)
Now for the printer. Download and run this patch to completely remove the printer from your computer.
The patch is password protected. The way around the password protected zip file is to open the zip file with Winrar or 7zip(.exe file)
Restart your computer.
After router is done, now setup your wireless print server/printer.
3300 Utility
3300 Firmware
Attach the 3300 to your computer using the USB Cable and insert the 3300 disk. Follow the instructions. It should ask you for the network ID, type of security and password.
Download the proper drivers.
XP Drivers
Vista 32-bit Drivers
Install the drivers, choose network, choose I'm using a wireless print server(if you do not see this, then choose add printer and you should see it then) and follow the instructions.
Thanks for contacting Fixya
Jun 05, 2009 | Dell 3300 Print Server
Wireless printing
The printer has o go through a router to work for the other two computers. The only other solution is setting up a wireless network with internet sharing on a HOC and share all file and printer services though it. The main PC would act as a router. for $40.00 you can buy a router and make it work.
Joe
May 17, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Wireless Printer communication problem with laptop
Please check IP, use manual IP for laptop and Printer. may AUTO IP cause this issue.
Apr 12, 2017 | Lexmark Office Equipment & Supplies
Wireless problem
First we need to check whether there is a communication between the computer and the all-in-one. Once print the network configuration page from the all-in-one and collect the IP address of the all-in-one and pste it on the address bar of the internet explorer and press enter, this should open the printers information page, if it is opened then there is a communication between the computer and then all-in-one. Now disable the firewall and antivirus and then try to install the drivers. If there is no communication then try to assign the IP address manually to the printer depending upon the computers IP address.
Apr 27, 2008 | HP Photosmart C7280 Printer
Help please....printer name does NOT appear
You must have a network set up, and you must enable file and printer sharing on the desktop. The laptop and the desktop should be in the same workgroup. Some firewalls will cause this problem.
Start with the network setup wizard in Settings/Network.
Jan 25, 2008 | D-Link NETWORK CARD DFE550TXREF Network...
Lexmark X7170 All-In-One InkJet Printer Logo
22 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
