Question about Linksys WRT160N Wireless Router
Linksys WRT160 router doesn't work
WHT160N router installed per instructions, but HP computer will not connect to the internet not will HP laptop. Router buttons flash but the on button in the center will only turn on and off by removing the power cord. Is the unit defective ? I am attempting to use internet provider for both computers. I utilzed system wizard for installation.
  • 1 more comment
  • Anonymous Jan 01, 2010
    WRT router is plugged into WESTELL DSL ROUTER. LINKSYS setup wizard completes the entire process and asks if I want to use both routers. I respond 'yes' and proceed. Message after completiton is: Network Configured and your connection to the internet is fully functional. HP laptop will not connect to the internet nor will HP pc connect either. Error message on both is check your connections. Both the DSL and WRT160 ROUTES have been reset to no avail. Any and all help appreciated.
    See above
  • Anonymous May 11, 2010
    is it connected in AP mode or Router mode ???
Anonymous
    Scholar:
  • 85 Answers
Wi-Fi Protected Setup Button
If you have client devices, such as wireless adapters, that
support Wi-Fi Protected Setup, then you can
use Wi-Fi Protected Setup to automatically
configure wireless security for your wireless
network(s).
To use Wi-Fi Protected Setup, run the Setup
Wizard, or refer to the “Wireless > Basic Wireless
Settings” section of “Chapter 3: Advanced
Configuration".
Wi-Fi Protected Setup LED (Blue/Amber) It
lights up blue when wireless security is
enabled. The LED flashes blue for two
minutes during Wi-Fi Protected Setup.
The LED lights up amber if there is an error
during the Wi‑Fi Protected Setup process. Make
sure the client device supports Wi‑Fi Protected
Setup. Wait until the LED is off, and then try again.
The LED flashes amber when a Wi‑Fi Protected
Setup session is active, and a second session
begins. The Router supports one session at a
time. Wait until the LED is off before starting the
next Wi-Fi Protected Setup session.
Posted on Jan 01, 2010
  • Anonymous Jan 22, 2010
    What is the operating system you are running?
I have a wireless network of computers, one wired and 2 wireless. in the correct setup, my other acer laptop doesn have internet, but s connected to the router, and this laptop im using CAN connect...
All the computers should have the same NETWORK NAME or SSID.
Recheck the settings and make an adhoc connection for each of the computers to your router.
You can also get a USB wireless adapter to enable ht NO internet laptop and connect them.
Just keep playing with the NETWORK SETTINGS.
Make sure all are connected to the SAME SSID.
Hope it helped.
God Bless You!
Feb 05, 2011 | Linksys WRT120N Router
I HAVE A NEW HP DESKTOP AND AN OLD LINKSSY WIRELESS G
Hi Vivian,
Chweck you cables and where they are conencted.
You will need to make sure that the Comcast modem is providing internet, you can do this by connecting your laptop to it using ethernet directly if it connects to the internet, that will be a good thing.
From your comcast Modem, the ethernet Cable should go to the linksys where it says "WAN". this should give you an internet connection and make your comcast modem communicate with your linksys Router.
Jul 22, 2010 | Linksys Wireless-G Broadband Router
I am currently using a Linksys BFR series router that works fine. I am trying to replace it with a Linksys WRT 300 N router. I go through the installation program provided by Linksys on my HP computer...
Are you trying to install the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 20, 2010 | Linksys WRT300N Wireless Router
The Wifi works (with my laptop) but my desktop
your laptop is able to go online using WI-FI.
desktop is connected to theb router but not able to go online. Do you see the port light on the router ?
check the Ip address on the computer. Check if there is any static IP address on the computer.
Click here for more information about the router and network
Jan 20, 2010 | Linksys WRT160N Wireless Router
Having followed all the instructions as per the 'set-up' disc I'm informed that there is no connection with the internet. the cables are ok , having been checked against other equipment. your unit does not...
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 29, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
When I try to connect my router to my laptop, the 321 error screen appears after about a minute. It says my ethernet cable is not plugged in properly, but it definitely is. Even the connection lights on...
This is a well documented problem with linksys routers. Go to google and type in "error 321 linksys". You will have to manually configure the router as stated on the linksys forum posts.
Jun 05, 2009 | Linksys WRT54G2 Wireless Router
Using a linksys g adapter card in my laptop cannot get internet
U have to configure the router.Then & then your internet will work.You can see the instruction set given with the linksys router or instruction set cd.Follow the steps,which will ask you ip,user name,password etc. information.Fill the right information save & reboot it must work.
Jan 03, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
No ip address from modem to linksys wrt160 n router
1).turn off the modem and the router.disconnected from the Internet ISP. and the computer.
2).disconnect the router from the modem.
3).turn on the modem.
4).connect the router to the modem, and turn on the router.
5).connected the computer to the router, adn turn on the computer.
if you are using wireless, waited about 5 minutes before turning it on.
goto control panel>>wireless network, and configure the wireless seting.
Nov 17, 2008 | Arris Touchstone 450a (CM450) Modem
Cannot maintain wireless connection
Try manually add the network. If the problems continue, I would turn the laptop in for repair/replacement (if it under warranty).
May 15, 2008 | HP Pavilion dv9730us Notebook
Linksys WRT160N Wireless Router  Logo
1,093 people viewed this question
Top Linksys Computers & Internet Experts
Mike
Jeffrey Groves
Jeffrey Groves
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
