Question about Honda Pressure Washer PSI 3000
I need to buy a pressure washer for residential/commercial work
I need to buy a pressure washer for residential work, decks primarily but I want extra power for tough stuff I was thinking 1)Simpson 13hp honda, ps4000 3.5gpm or 2)Landa 13hp honda gx 3200 3.5gpm or 3)Pressure pro 13hp honda gx w/general ez4040 ALL DD, would be getting used aprox. 10hrs a week. whats your opinion?
Posted by mrggtwy on
Anonymous
    Sniper:
  • 56 Answers
Were I to pick from one of those three, I would pick the Landa. The most reliable pumps are Hotsy and since Karcher bought Landa and Hotsy, those three brands now have Hotsy pumps, though it doesn't say it on the machines.
Posted on Jan 02, 2010
How do I reset the mixture screw on my Honda GC series 1800psi 4.0 HP premium residential pressure washer?
use a starting setting of all the way in then back out 1 1/2 to 2 turns adjust for best run after that
Jul 15, 2015 | Honda Garden
My 13hp gx390 honda engine on my power washer is making a clunking noise every so often why
Is it the engine of the unloader valve in the system.
Honda engines never clunk
Thanks qwashers
Oct 18, 2014 | Garden
I bought a Simpson 3000 psi gas pressure washer. When I changed the oil (first time) I found the oil does not drain out into the pan but spills over the right wheel. I called a Honda dealership and
Easiest thing to do is buy a pipe nipple of appropriate thread size, a female thread elbow the same thread size and a male threaded plug to match the coupling. Turn the pressure washer onto its side with the drain plug pointing up. Remove the drain plug the screw in the pipe nipple where the drain plug was. Thread on elbow to other end of the pipe nipple and then screw in plug to the open end of the elbow. Buy a nipple that gets you just past the frame of the pressure washer and point the elbow at any downward angle you need to avoid draining onto the wheel.
Jul 22, 2014 | Simpson Garden
Im not getting the simpson 3200 psi to shot out water
Give us a all when you. An be at the washer.
http://www.ppe-pressure-washer-parts.com/page/419383926-32577450
Nov 03, 2013 | Simpson PS3200 Powershot 3200 Psi Direct...
Pull cord compartments have come off
With your question, I'm not sure if your looking for another or what your specific needs are but I believe this is it.
http://www.ebay.com/itm/NEW-PULL-START-RED-RECOIL-COVER-11HP-13HP-FITS-HONDA-GX340-GX390-/111147183055?pt=LH_DefaultDomain_0&hash=item19e0e36bcf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steve_f5a6ca85b5d1ffc9
Oct 02, 2013 | Simpson WaterBlaster Commercial Gas...
13hp honda motor what is the right psi for it
It will depend on the pump that you have but the most common versions will be the 13HP PC4-35324 which is a direct drive unit or a PG4-35324 which is a belt drive unit. In both cases the machine would be 4GPM at 3500PSI.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
800.247.8103
503.255.6508
Jun 03, 2010 | Honda Landa PG 3500 PSI Pressure Washer
I have a GX Honda 160 5.5 and cant get the soap suds to work
Are you using a soap nozzel? If not the soap injector will not work.
Jan 25, 2010 | Simpson WB4200 Water Blaster 4200 Psi Cold...
Honda Pressure Washer PSI 3000 Logo
277 people viewed this question
Top Honda Garden Experts
JOHN LAPIER
Marvin
Marvin
Tim Venetis
Are you a Honda Garden Expert? Answer questions, earn points and help others
