Question about Tomtom ONE 130 GPS Receiver
Cannot get our new Tomtom GPS one 130 to show English in instruct
Just purchased a new TomTom One 130 GPS navigation system and cannot get it to give information or instructions in English.
Posted by bgpentz on
Anonymous
    New Friend:
The tom tom won't turn on
Posted on Jan 10, 2010
Anonymous
    New Friend:
  • 6 Answers
Connect your device with TomTom Home and access the memory (like if it was an external disk)
Create the following 2 files without ant extension in the root:
cleanflash
runclean
It will reset your devide to the original settings.
When starting it will ask you which language you want to use.
Posted on Jan 01, 2010
TomTom GO 2405TM how do I get started?
Reading the manual cover to cover is a great start :>)
Search Results
TomTom GO Manual
download.tomtom.com/open/manuals/go5/refman/Main_menu_eng.html The screen will appear in black and white until your TomTom GO locates your ... Wherever you go, it will always give you instructions that will take you to your chosen ...... Visit www.tomtom.com for technical support and contact information.
[PDF]TomTom GO
download.tomtom.com/open/manuals/new_GO/refman/TomTom-US-RG-en-us.pdf TomTom GO. Reference Guide .... Connect to TomTom services using a different smartphone . ...... When you go to Current Route -> Show instructions you can ...
[PDF]TomTom GO Quick Start Guide
download.tomtom.com/open/manuals/go5/ttgo5_qsg_uk.pdf NOTE: Do not expose TomTom GO to high or low temperatures. We recommend that you .... Follow the on-screen instructions, using your finger on the touchscreen ..... For technical support information please visit our website at www.tomtom.
Tomtom Gps Manual: TomTom GO 2405TM 4.3-Inch Portable ...
ttgpsmanual.blogspot.com/2012/03/tomtom-go-2405tm-43-inch-portable.html Mar 10, 2012 - TomTom GO 2405TM 4.3-Inch Portable Bluetooth GPS Navigator with ... The 2405 TM's sleek 5-inch glass touchscreen allows you to easily ...
TomTom GO 2405 TM review - Roadshow - CNET
https://www.cnet.com/roadshow/auto/tomtom-go-2405-tm/review/ Rating: 4 - ‎Review by Antuan Goodwin
Nov 23, 2010 - The new Go 2405 TM and 2505 TM are among the best GPS devices that ... users to check the manual to learn what commands are available. tomtom go 2405 tm manual Google Search
Oct 16, 2017 | Tomtom GPS
Tom Tom sim card error
Hi.
You need to replace the SIM card located on a slot at the side of your GPS.
Before replacing the SIM try turning off the TomTom, removing and reinserting the SIM.
The card can be purchased at any TomTom authorized seller, or contacting TomTom online.
See Contact - TomTom, portable GPS car navigation systems
Jan 08, 2010 | Tomtom ONE GPS Receiver
My Main menue language is German on my TomTom 130 GPS
In the menu, you should find the settings for language.
Now, If you don't speak German, this can be a problem.
If you use your computer to translate, you can do it.
Go to http://babelfish.yahoo.com/ and select the languages as required (German to English). Enter the commands you see on the TomTom, and navigate that was until you see the language settings.
Dec 26, 2009 | GPS
I have a TOMTOM 130 S AND ITS IN A DIFFERENT LANGUAGE.... HOW DO I CHANGE IT TO ENGLISH??
Go to Preferences -> Change language -> Select English.
You may also refer the page # 31 in the User Guide of the GPS Device for more information about this.
Check this link to download the User Guide of the GPS Device.
http://download.tomtom.com/open/manuals/one30/manual.htm
http://download.tomtom.com/open/manuals/one30/refman/TomTom-ONEv4-en-US.pdf
Good Luck!!!!!!!!
Oct 04, 2009 | Tomtom ONE 130S Car GPS Receiver
TomTom Home software appears in a different language
You can reset your language by following this tutorial on TomTom's Website
Dec 26, 2008 | Tomtom ONE 130S Car GPS Receiver
Reset
Start up your TomTom and find the preferences icon. The lips icon has the option of changing the voice, and you can switch back to English from there.
Oct 17, 2008 | Tomtom ONE 130 GPS Receiver
Tomtom One 130 shows pic of Tomtom, flashing x, pie chart icon on left after using Tomtom Home.
TomTom Home must have corrupted the TomTom's operating system. That is what that symbol means. Contact TomTom support and tell them what model you have and they will walk you through getting the correct version installed.
Oct 14, 2008 | Tomtom ONE GPS Receiver
Open Questions:
My tom tom one 130 stays with an orange picture, and a red circle with an X. It also says something about an error when I try to upgrade it... like this.... ERROR: Internal/Malformed#createItemFromDLL/Internal/Malformed: Exception: Lo sentimos pero HOME no puede completar esa tarea. Inténtelo de nuevo más tarde o póngase en contacto con el departamento de atención al cliente. Para resolver los problemas con los elementos almacenados en su dispositivo, le recomendamos eliminar y volver a instalar el elemento. Malformed Item info: name = id = version = 0 locationType = 1252 install location physicalType = 1504 metadata = Severity: 1105 - Internal/Malformed: Malformed: Lo sentimos pero HOME no puede completar esa tarea. Inténtelo de nuevo más tarde o póngase en contacto con el departamento de atención al cliente. Para resolver los problemas con los elementos almacenados en su dispositivo, le recomendamos eliminar y volver a instalar el elemento. Must not be empty Bad value: "" (type: string) Severity: 1105 Stack: 0. chrome://tthome/content/logic/model/ttItemFactory.js:43 let wrapper = new Exception(null, newId); 1. chrome://tthome/content/logic/model/ttItemFactory.js:90 var modelitem = this.createItemFromDLL(dllitem, onlyType); 2. chrome://tthome/content/logic/model/ttItemList.js:55 var models = gApplication.itemFactory.createItemListFromDLL(dllItemList, onlyType); 3. chrome://tthome/content/logic/ttTask.js:315 itemList.addItemListFromDLL(doneLocation.deviceNavItems()); 4. chrome://tthome/content/logic/util.js:79 return func.apply(obj, arguments); 5. chrome://tthome/content/logic/dllUtils.js:73 this._successCallback(this.successText); 6. chrome://tthome/content/logic/dllUtils.js:58 this._success(); CAUSE: Internal/Malformed: Malformed: Lo sentimos pero HOME no puede completar esa tarea. Inténtelo de nuevo más tarde o póngase en contacto con el departamento de atención al cliente. Para resolver los problemas con los elementos almacenados en su dispositivo, le recomendamos eliminar y volver a instalar el elemento. Must not be empty Bad value: "" (type: string) Severity: 1105 Stack: 0. chrome://tthome/content/logic/serverinput.js:84 throw new Malformed("Must not be empty", uc); 1. chrome://tthome/content/logic/serverinput.js:218 var str = this.nonemptystring(uc); 2. chrome://tthome/content/logic/model/ttNavItem.js:265 this._idstr = makeSafe.contentidstr(item.id); 3. chrome://tthome/content/logic/model/subtype/ttVoice.js:36 ttNavItem.prototype.importFromDLL.apply(this, arguments); 4. chrome://tthome/content/logic/model/ttItemFactory.js:39 result.importFromDLL(item); 5. chrome://tthome/content/logic/model/ttItemFactory.js:90 var modelitem = this.createItemFromDLL(dllitem, onlyType); 6. chrome://tthome/content/logic/model/ttItemList.js:55 var models = gApplication.itemFactory.createItemListFromDLL(dllItemList, onlyType); 7. chrome://tthome/content/logic/ttTask.js:315 itemList.addItemListFromDLL(doneLocation.deviceNavItems()); 8. chrome://tthome/content/logic/util.js:79 return func.apply(obj, arguments); 9. chrome://tthome/content/logic/dllUtils.js:73 this._successCallback(this.successText); 10. chrome://tthome/content/logic/dllUtils.js:58 this._success();
Aug 17, 2010 | Tomtom ONE 130 GPS Receiver
See all Tomtom ONE 130 GPS Receiver Questions
Tomtom ONE 130 GPS Receiver Logo
363 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Ekse
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
