WHEN I TURN ON THE TOSHIBA REGZA, ON A CHILLY MORNING, THE RIGHT HALF OF THE SCREEN IS FUNKY. IT IS KINDA TILED AND BLURY, AFTER ABOUT 10-15 MINUTES IT IS OK AND SCREEN IS FINE. TV IS ABOUT 2 YEARS OLD AND SHOULDNT ACT LIKE THIS. WHAT COULD THE PROBLEM BE?
hi this fault sounds like a bad tab/ribbon fault, at top of the tv are ribbons connector to the screen, when one is faulty the heat makes them flex causing this fault, you can bond the ribbon down with a bit of rubber to stop it flexing, but this not a permanent repair as it is a screen fault. hope it helps
This is a catastrophic and known failure of older Toshiba sets, not much you can do, try to take out a retrospective extended warranty, wait a month and claim, good luck.
Yes the screens can be replaced and if you're half decent with a screw driver (and have the patience of a monk) it's probably worth attempting yourself.
Ball park figure for a new screen is around £150 but I recommend you get on eBay and buy either a used screen or smashed up laptop and take the screen off that. It should work out a much cheaper repair.
its in warranty ship it, the problem is actually not common but it is a problem it is related to the processor on the main board, and um don't trust salesmen to tell you about repair issues. They really don't have a clue. if you need a tv for to weeks then rent one for two weeks they are not that expensive to rent
