Question about Acer AL1713 17" LCD Monitor
Acer al1713 monitor and the power led flashes form yellw to green
I have an acer al1713 monitor and the power led keeps flashing from yellow to green. i have fixed a blown resistor and two compositor on this monitor already it worked for a second and now it only displays "acer" and "no signal" when no cable is plugged in. andwhen the back lite shuts off a high pitch sound can be heard i believe it to be a compositor but i cant find any that look bad. i have look very closely at every one of them.
does anyone have an answer to my broblem or should i say it is finaly dead.
i do have the service manual
Posted by boo5x on
Anonymous
  • 585 Answers
The short answer, replace all of the capacitors. They can be bad without swelling. And there may be one 47mf/16v off to itself, if it fails, monitor will not come on. Also, check the menu or mode setting to make sure your VGA/DVI agrees with the cable if the monitor has both.
Posted on Jan 01, 2010
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
Hanns-G HC194 monitor, no screen, led is flashing in green
hello,
The green flashing power led is a standard symptom of a failure in the power supply board. We have an article about how to repair this unit posted on our web site at: http://www.ccl-la.com/blog/index.php/repairing-a-hanns-g-hc194d-with-flashing-power-light/ If you can solder then you should be able to do the repair yourself, if you don't want to do the repair we do offer a repair service, that information can be found here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps you out, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 27, 2010 | Computers & Internet
Monitor power light flashes yellow/green
the monitor power light turns green and then switches back to yellow but there is no signal.
Nov 28, 2009 | Acer AL1917W LCD Monitor
Acer AL1713 flashing power LED
Take the monitor apart, and replace any swollen electrolytic capacitors. If that doesn't help (and it probably will) then check for bad soldering and resolder any joints.
But if the capacitors are swollen that will almost certainly fix your issue.
Jun 08, 2009 | Acer AL1713 17" LCD Monitor
http://www.lcd-television-repair.com/1-Acer.pdf
Hi
Check out above link for AL1713 schematics and service guide.
Based on your explanation it seems you have some shorts problems with the other board.
Jul 27, 2017 | Acer AL1713 17" LCD Monitor
My monitor is new .. the screen stays black and the power button flashes green ... how do i fix this ????
Hi!
I have acer al1716 LCD and whan the computer is turn on, the lcd led turn green but the lcd is showing black, what i can do?
thank you!
Apr 16, 2009 | Acer AL1716 17" LCD Monitor
Monitor Not Showing A Picture. Light flashes Yellow and Green.
use the onboard graphics instead of a seperate graphics card (if installed) to test the screen.if it still doesn't work then unplug your monitor from the mains supply and plug in again to reset it. i doubt it's your monitor that is the problem though. but look on the back of your pc for another connection for your screen. the onboard graphics connection is normally vertical near your ethernet port and mouse and keyboard inputs.
please rate me and give me a fixya! if it helped.
Apr 05, 2009 | Acer AL1713M 17" LCD Monitor
Power button flashing green on and off. No Picture
What type of monitor do you have? I need to no if the power supply or cord plugs directly into the LCD Monitor? These questions are important! Please answer these questions, I will be able to give you an answer!
Nov 25, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1713 17" LCD Monitor Logo
301 people viewed this question
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Michael Thomas
Michael Thomas
