Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
I have tv sony KV- XJ29M50 when switches on comes on for 10 - 30
I have sony KV- XJ29M50 when switches on comes on for 10 - 30 seconds and then shuts off automatically
Posted by mohdroslik on
Anonymous
    New Friend:
  • 76 Answers
Shutdown trouble, some leak capacitor need to be replaced
Posted on Jan 01, 2010
Sony KV-XJ29M50 29
vertical setting solution
Sep 05, 2012 | Sony KV-XJ29M50 29" TV
CAN WE CONNECT EXTERNAL SPEAKERS TO SONY KV-XJ29M50 TV
Check whether there is an audio out RCA type sockets at the rear side of the TVm marked as Audio Out. If so, you can connect these sockets to any exterenal audio amplifier, by connecting Av cable in between devices, and can listen audio from external speakers. Picture of AV cable is shown. Keep free its yellow pins. Use red and white.
Jun 08, 2012 | Sony KV-XJ29M50 29" TV
Sony KV-XJ29M50 top half vertical problem i.e shrink
Check and replace all electrolytic capacitors at its vertical output section. There will be 5 or 6 numbers. Replace all of them at the same time.
Apr 14, 2012 | Sony KV-XJ29M50 29" TV
Where is the vertical part of the Sony KV-XJ29M50, or what type of IC in that part?
Hello
Vertical output Ic is in the A board itsef. It is an SIL type [Single In Line type] Ic, screwed onto a metal heatsink to radiate heat out of it while working.
OK.
Jul 29, 2011 | Sony KV-XJ29M50 29" TV
The easiest way to identify the Vertical drive IC is to trace the horizontal Yoke coils to the board, the vertical coils to the board must lead to the vertical drive output where the IC is seen normally a inline IC with a heat sink.
Check if the solder joints are weak if so solder and check.
Dimana letak bagian vertikal dari Sony KV-XJ29M50, atau apa tipe IC di bagian itu ?
halo
Output IC vertikal dari himpunan ini dapat terletak di A dewan itu sendiri. Ini adalah SMD [Permukaan Gunung Tipe] ic, mengacaukan ke heatsink meatus untuk memancarkan panas dari itu saat bekerja. OK
Sony Trinitron WEGA KV-XJ29M50 29" TV - Dead, LED flashes 2 times
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 24, 2010 | Sony KV-XJ29M50 29" TV
KV-XJ29M50 29" TV-Loud thumping sound on startup
Symptoms are not related,what you hear is the high voltage turning on and that is normal if it only does it for less than a second,the grainy picture might be intermitant,dont turn it off,when the picture is grainy tap the side of the set to see if it racts and if it does you know you have a loose conection.This could be outside because of a loose ground on tha cable or inside in the tuner.
Sep 22, 2006 | Sony KV-XJ29M50 29" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
231 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
