2000 GMC Yukon XL Logo
Posted on Jan 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Loud popping noise when turning.Seems to be coming from the drivers side front wheel
Anonymous
Level 3:
  • Master 962 Answers
  • Posted on Jan 01, 2010
Anonymous
Master
Level 3:
Answers
962
Questions
Helped
478143
Points
2866
  1. Something is rubbing against or hitting the steering column: Locate and remove objects contacting steering column.
  2. Your steering linkage needs to be lubricated: Lubricate steering linkage.
  3. A part of the steering linkage is loose or damaged and needs to be replaced: Replace steering linkage parts as required.
  4. Your tires are hitting or rubbing against something: Inspect tires and wheel wells and repair or relocate rubbing parts.
  5. You have worn suspension pieces: Replace worn suspension pieces.
Anonymous
Level 2:
Sergeant:
  • Expert 191 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
191
Questions
0
Helped
63175
Points
584
This could be a bad inner axle joint check to see if the axle boot on the left side is torn or missing also check the wheel bearings and tie rod ends by jacking up the front of the vehicle one corner at a time and grab the tire at the 9 o'clock and 3 o'clock position and wiggle it back and forth looking for excessive movement in the tie rod ends then reverse your hands to the top and bottom of the tire and try moving it from top to bottom checking for excessive wheel bearing movement it shouldn't move in or out at the top or bottom
I have a 2007 Saturn Ion. While driving, there is a grinding noise that seems to increase with speed. The grinding sounds like it's coming from the front driver side wheel. I have already changed the wheel...
Your wheel bearings need replaced,just replaced both front ones on my car,Then you will need to have your tires balanced,rotated and front end aligned.Mine was coming from my front driver side,it was loud,replaced,then the passenger side was making a noise,but not as loud,now it is like new.
When I accelerate forward from a comp stop my car makes a loud grinding/screeching by the front driver side. Once running the noise stops but until it catches speed it makes the sound. What is that?
It could be several things, and I'm going to assume that the vehicle is front wheel drive.
First possibility is the constant velocity joint on the driver's side is worn out.
Second possibility is the wheel bearing on the driver's side.
As to the shaking at 70+mph, you may have an alignment problem, or some issues with the suspension components on that side of the car.
Does the noise get worse when accelerating from a stop, and turning, at the same time?
Loud thumping from under drivers side that started with a squeal.
16 costly car noises - Bankrate.com
www.bankrate.com/finance/money.../16-costly-car-noises-1.asp...
BankrateYou should not ignore certain thumping, banging, clicking and squealing sounds. These sounds often rear their heads or intensify whenever the driver takes ... Hissing or sizzling under the hood: Heard when the engine is first shut off, .... my rear right wheel makes a loud bang when switching from park to drive/reverse.
Sounds coming from drivers side front wheel - AnandTech Forums
forums.anandtech.com > Social > The Garage
AnandTech
Dec 1, 2009 - 21 posts - ‎10 authors
Sounds coming from drivers side front wheel The Garage. ... slightly left, I get a slight metalish-squealing sound coming from the drivers side front wheel area. ... but before I start the wild and expensive goose chase of bringing it to mechanics I ..... Those twoloud clunks when turning hard right give it away.
Ford Explorer Questions - Thumping from front end - CarGurus
www.cargurus.com > Questions > Ford > Explorer
CarGurusDec 22, 2009 - Thumping from front end - I have a hard thumping noise coming from ... without problem then I'll take a turn or something and it will start. ... I just recentlystarted having a rubbing and thumping and squeaking noise in the right front sidewhen driving ... Thumping sound coming from under the truck 4 answers.
Car Noises: Consumer Reports - Consumer Reports Online
www.consumerreports.org/cro/...noises/.../index.htm
Consumer Reports
Loud grinding/clunking noise when driving, lessens when I press the brake
Loud Noise Unknown Origin - Ask the GM Technician - GM-Trucks.com
www.gm-trucks.com > ... > Ask the GM Technician
Jun 30, 2006 - 7 posts - ‎3 authors
I get a loud clunking, grinding noise while turning to the right only, and ... I moved the passenger side tire to the rear driver side just in case it ...
can bad wheel bearing/hub cause loud clunking noises?
www.jeepsunlimited.com/.../showthread.php?...loud-clunking-noises
Nov 12, 2009 - 14 posts - ‎6 authors
driving home, i noticed some metal clunking sounds coming from the front driversside. at ... hmmmm....if it's grinding, then probably a bearing.
Front Clunking sound when driving straight. - TDIClub Forums
forums.tdiclub.com > ... > VW MKIII-A3/B4 TDIs
Dec 21, 2011 - I have a sporadic clunking noise from the drivers side front end. '98 jetta ... If I try to coast it gets really louder and more pronounced. ... whirring orgrinding could be several things: wheel bearing, brake pads due to a caliper ...
Quick Guide to Diagnosing Differential & Driveline Noises ...
Loud popping sound in front driver side while driving
Sounds like the sway bar might be broken. Turn the steering wheel so you can look into the inside of the fender behind the wheel. There is a large bar that connects both the front lower control arms together, sometimes this bar breaks and rubs the ends together causing a popping noise.
1helpful
2answers
There is a knocking in the front wheels primarily in the drivers side that seems to be consistant with the rotation of the tire meaning when I slow down the noise gets slower when I speed up the noise...
Sounds like a bad constant velocity shaft/axle. They are about $90 rebuilt, and are easy to replace, but involves removing the tire, and spindle.
1helpful
Loud humming noise from front end of Durango 4 x 4
You have a hub/wheel bearing going out. You need to jack up the vehicle on each side. Grab the top and bottom of the wheel and try to move it in/out at the top and bottom. If this does not work then roll the wheel as fast as you can and see if you can hear which one it is. Good Luck.
3answers
1helpful
Front End Noise, Chev Cavalier
It sounds like you have a bad c v or constant velocity joint. Look under the car next to the wheel look for a rubber accordian type unit, if the rubber is torn or lose the grease has escaped and damaged the joint. You can replace it yourself, but if your not mechanically inclined would say take it to a shop.
Top GMC Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a GMC Expert? Answer questions, earn points and help others
