I PRES THE SCAN BUTTON AND IT TELLS ME TO SELECT THE ONLINE TAB FOR SCANNING. AFTER I DO THAT, I SEE AN IMAGE OF A MONITOR W/ A DOCUMENT ON IT.THE SCREEN READS WAITING... AT THE TOP AND ...NETWORK SCAN AT THE BOTTOM
Firstly, the machine must be connected to a pc or network. Secondly, you must scan the document to a pc so, after you have switched on, as you have, the scanner so that it says 'online' you will need to go to the pc and 'PULL' the document to the pc from the scanner. However, to do this you will need to have installed NETWORK SCAN GEAR on your PC inorder to SCAN. When you install the software, you will need to DISCOVER the scanner before it will be ready for use. So, a recap:
1. You NEED a program called NETWORK SCAN GEAR on your PC
2 Your ir2230 must be connected to a PC or network
3 You need to DISCOVER your ir2230 from your PC
4 You then need to INSERT picture FROM SCANNER and select your ir2230 from within a program such as WORD using NETWORK SCAN GEAR
Good luck
