Question about Insignia Televison & Video
DVD player is saying "Wrong region"
I am trying to play a movie in the DVD player and getting the error message "wrong region".
  • 2 more comments
  • Anonymous Jan 01, 2010
    There is no place to enter a region which is crazy. The only thing remotely close is "language" (French, English or Spanish) and English is selected. Any more ideas?? The TV is an Insignia. Thanks
  • Maliik Prior
    Maliik Prior Jan 26, 2014
    Does anyone know how to fix it?
  • Anonymous Mar 18, 2014
    I have a xtron flip out radio n it keep saying warning stop dvd player can't play movie
  • Lyn Downing
    Lyn Downing Jun 18, 2014
    How do you change the region
Anonymous
    New Friend:
  • 27 Answers
Region codes are as follow. Region 1 North America, Region 4 South America, Australia, Region 2 Europe, Region 5 Asia Major,Africa,Region 6 Asia Minor, Probably your DVD is from another region....hope this helps
Posted on Jan 01, 2010
  • 1 more comment
  • Natalie Matthews Dec 05, 2011
    would the UK be region 2 then? as i am having the same problem with my p90x dvds i ordered from beachobody. There is nowhere on my dvd player to change region? does this mean i have to go and buy another dvd player that will play them?
  • Julia Thomas Dec 10, 2011
    I'm having the same problem trying to play DVDs purchased in the UK in the US. The DVDs are season 1 & 2 of Downton Abbey - season 2 hasn't been shown in the US yet but the problem occurs with season 1 as well.
  • Maliik Prior
Nanny
    Genius:
  • Insignia Master
  • 2,351 Answers
You can get a region free player program on your computer and then you will be free from the region code issues. You could try Leawo Blu-ray Player which is a free Blu-ray player and you could use it to play any DVD and Blu-ray discs.
Posted on Jul 04, 2019
DVD's wont play - says wrong region but they are compatible
To change the Region code on your player, open Control Panel - System - Hardware - Device manager, and click on DVD/CD ROM drives, then right click on the DVD drive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have been made.
NOTE you can make only 4 changes and the player will lock permanently on the 4th change.
If you want to play DVD from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software that allows you to play DVDs from any region. There are several available on the Internet but my favourite is DVD-Region Free
www.dvdidle.com/dvd-region-free.htm
Nov 23, 2009 | HP Pavilion dv9000z Notebook
Solutions to incorrect disk error c105 & c104
Hello gjbrokke,
First make sure the disc is compatible with the dvd player (CD-R+ , or CD-R - )
Second make sure the region code of the dvd you burned is compatible with the dvd region settings on your dvd player.
One of those two are preventing the disc from playing in your sansui player.
May 19, 2009 | Sansui VRDVD4005 DVD Player/VCR
Blu Ray Region settins
about changing ur region, theycan be changed from control panel.
go to control panel
go to regional & launguages settings
and change it to United States (US)
now reinstall ur HP's DVD program, and try it then.
i guess this will work..
Apr 12, 2009 | Computers & Internet
DVD Player D1816 shows Wrong Regional Disc message
Many DVD players are preset to one region and if you use a DVD destined for any other region, the player will refuse to play. Some players have the option to change this to universal mode. Check your player's manual if yours has this facility.
Yes. You can play VCD movies and and Audio CDs on most players.
Mar 18, 2009 | GPX D1816 DVD Player
Want to unlock Philips DVD player (DVP320)
Did you follow these instructions exactly? If you pressed 9990, as you mentioned, it will not work. You need to press 99990. Do you see region "0" on the display?
start the player without any DVD in it.
open the lid.
while the lid is open press 9,9,9,9,0
you should see region 0 displayed.
close the lid.
Your DVD player is now region free.
note:
replace 0 with 1 to 6 at to set the wanted region number if needed.
Mar 05, 2009 | Philips DVP320 DVD Player
GPX portable DVD model PD808B - wrong region message
Turn on power. Open lid. Enter 9735 with the remote and press 'enter', you can now choose between regions on the screen. Select the desired region unlock and press 'enter'. This works well!
Benony Jonsson
Feb 20, 2009 | GPX PD808B Portable DVD Player with Screen
"Wrong Disc" error message
do you insert DVD-/+R? or original DVD
  1. if you insert original DVD you have to search the code to change your regional code and try with ALLZone. search on the web with your model.
  2. if you insert DVD-/+R probaly you have just to clean up your laser with a clean up CD
Apr 22, 2008 | Televison & Video
The DVD player does not recognize disks that it used to play before.
It sounds like the DVD region (a setting in both your OS and your DVD hardware) may have been changed. DVD regions are the agreed upon method (by entertainment companies, hardware manufacturers and governments) to limit cross-border sharing of media. Most valid (read: non-pirated) DVDs have a region code. Your DVD drive will only play DVDs with a region code that matches the DVD region code set on the DVD drive.
You didn't mention your OS but if you are running Windows XP then go to Start->Control Panel->System->System->Hardward->Device Manager and find your DVD player. Right-click the DVD player and select Properties from the menu and you should see a properties dialog-box with a DVD region tab. This is where you can change the DVD region that your player will recognize. Be careful, don't play around here, most DVD players have an embedded limit on the number of times (4-or-so) the DVD region can be changed.
Hope this helps.
-Ed
Mar 31, 2007 | NAD C541 CD Player
Televison & Video Logo
1,982 people viewed this question
Top Insignia Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
