1. Place food in stoneware according to recipe.
2. Plug in Smart-Potâ„¢ slow cooker. The Power light will begin to flash
indicating that the unit is plugged in, but not turned on.
HOW TO PROGRAM YOUR SMART-POTâ„¢ (CONT.)
3. Push the Cook Time button to scroll through the timed cooking
options. Push once and the 4 hour light will illuminate, twice and the
6 hour light will come on, etc. Select the time based on the length of
time indicated in the recipe. Two time options are usually given. The 4
and 6 hour settings are the HIGH temperature setting and may be
used when you want your food done quicker. The 8 and 10 hour
settings correspond to the LOW temperature setting and is used for all
day cooking. In addition your Smart-Potâ„¢ can be set to the Warm
Setting by scrolling through the timed cooking options until the warm
light illuminates.
NOTE: The Warm setting is for keeping already hot food warm. Do not use
the warm setting to cook or reheat food.
4. When the cooking time is completed, the Smart-Potâ„¢ slow cooker will
automatically shift to the Warm setting and the Warm light will come
on. NOTE: We do not recommend using the Warm setting for more
than 4 hours.
5. To turn the Smart-Potâ„¢ off push the OFF button. Unplug unit from the
wall outlet.
6. For other recipes that give a range of times, select the time closest
to the setting on your Smart-Potâ„¢. For instance a recipe calling for
cooking time of 7 to 9 hours on LOW, set your Smart-Potâ„¢ to 8 hours.
NOTE: If power goes off then power light will blink and settings must be
reset. If cook time is changed before the cycle is complete the time will
reset to the new setting.
Thanks for choosing FixYa,
Kelly
2. Plug in Smart-Pot slow cooker. The Power light will begin to flash indicating that the unit is plugged in, but not turned on.
3. Push the Cook Time button to scroll through the timed cooking options. Push once and the 4 hour light will illuminate, twice and the 6 hour light will come on, etc. Select the time based on the length of time indicated in the recipe. Two time options are usually given. The 4 and 6 hour settings are the HIGH temperature setting and may be used when you want your food done quicker. The 8 and 10 hour settings correspond to the LOW temperature setting and is used for all day cooking. In addition your Smart-Pot can be set to the Warm Setting by scrolling through the timed cooking options until the warm
light illuminates.
NOTE: The Warm setting is for keeping already hot food warm. Do not use the warm setting to cook or reheat food.
4. When the cooking time is completed, the Smart-Pot slow cooker will automatically shift to the Warm setting and the Warm light will come on. NOTE: We do not recommend using the Warm setting for more than 4 hours.
5. To turn the Smart-Pot off push the OFF button. Unplug unit from the wall outlet.
6. For other recipes that give a range of times, select the time closest to the setting on your Smart-Pot. For instance a recipe calling for cooking time of 7 to 9 hours on LOW, set your Smart-Pot to 8 hours.
NOTE: If power goes off then power light will blink and settings must be reset. If cook time is changed before the cycle is complete the time will reset to the new setting.
That is pretty much the entire user instructions. Everything else is warnings, cautions, and oh yes; don't submerge it in water yadda yadda....
Kelly
