Question about GE Ultrasonic 2.1 Subwoofer Computer Speakers
What is the voltage for the GE Ultrasonix 2.1 Computer Speakers - 98903
Posted by angelram7296 on
Anonymous
    New Friend:
THE WALL TRANSFORMER STEPA DOWN VOLTAGE FROM 120 VOLTS AC TO 12 VOLTS AC @800 MILLIAMPS
Posted on Oct 03, 2010
I need to know the voltage of the speaker for ac adapter matching
The speakers may have a label that has the voltage printed on it.
You can check the Bose WEB site for the specs of your model speakers. You need to know the polarity of the connector, if you get it wrong you could destroy your speakers.
You may need to contact Bose support if the specs do not help you.
Cant get my ultrasonix 2.0 speakers to work?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
2answers
I need specifications about the power supply for for the Maxell FPS-1 2 speakers ...
Input Voltage: 110 V AC
Power Source: Power Supply
Frequency Response: 70 Hz to 18 kHz
I have Mercury 2.1 white speaker.It works fine for half an hour but after that the woofer's sound stops-start frequently at highest bass but when I reduce the bass It works normally with no distortion.
If highest bass means you are boosting the bass for effect then it may be some form of speaker protection cutting in.
The most likely is a Polyswitch, which increases in resistance as it heats up when too much current is going to the speakers. The sound resumes when it has cooled down.
I need the input voltage for ac adapter for my GE 98903 2.1 Pro Speaker System
The AC adapter input voltage is 120 Volts AC as it plugs into a wall outlet. I suspect you want to know the output voltage of the transformer. If you have the old transformer the output voltage is listed on the transformer top. May be hard to read but it is there. This system is also sold under then brand name Jasco. The Input voltage of the system should also be printed next to the power connection or on the speaker itself.
2helpful
Can't adjust bass and treble
The only adjustments available on the unit are Volume and Bass (Subwoofer Level). There are no Mid-Bass or Treble adjustments.
Computer speaker problem
Make sure the cable connected to INPUT directly connected to your sound card on GREEN plugin
Best Luck!
I need to reinstall the jasco 98903 2.1 speakers on my win xp.
Speakers in a sense do not need drivers, the component it the pc has to have them to provide sound. So find the drivers for your sound card on the disc that came with your computer. Or go to the product website and find the drivers there. After that u should be A for away.
I recently had my hard drive redone and need to reinstall a ge 98903 2.1 pro speaker system. I have no install disk and can find no driver or software info. to download on the net . Help without this i...
do you have Onboard soundchip? or pci slot sound card?
if you have onboard soundchip..just try to install your motherboard cd installer,the sound driver is included in it. if you lost the cd,try to download it from its brand website.
if you have pci slot sound card. try to find from the card its name,brand and model and try to find and download the driver from the net.
hope you'll not lost... ;-)
Speaker hook up
Krout
depending on the speakers, (2 way ) you can use a splitter, but you also hace to check if your sound card support 2 speakers too, or what brand its?
but the splitter in this case , if you have no other problem, is the best bet.
good luck
Top GE Audio Players & Recorders Experts
Ekse
Rob Hill
Rob Hill
Joaquim Martins
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
