Whirlpool Accubake SF362LXTS Kitchen Range Logo
Posted on Dec 31, 2009
My oven flame is yellow and orange. you can smell
My oven flame is yellow and orange. And you can smell gas during the preheating process. It take a tremendous amount of time to reach usable temperature. Would running the self cleaning cycle help?
Anonymous
Level 1:
  • Contributor 35 Answers
  • Posted on Jan 02, 2010
Anonymous
Contributor
Level 1:
Answers
35
Questions
0
Helped
10748
Points
63
Open air vent on main burner. check burner orifice and pressure regulater
2answers
Orange glow after oven burners were lit, thenflames in oven
Sounds like maybe some grease or something had been spilld and then caught on fire while you preheated the oven
2answers
I have a maytag gas stove model mgr5720adh When I use the oven during the preheat is fine it does take longer to preheat but when it maintaining the temp I start smelling gas.
Change the igniter the igniter is not getting hot enough to open the safety valve and what it does there's not enough heat on the igniter to ignite the flame of the burner
I have a Preway gas wall oven. Repair man said it was 55 years old. Guessing he couldn't know the exact age so late 50's/early 60's. It remains lit until about 3 or 4 minutes of preheating. Then the flame...
Try contacting them directly- I bet they might be able to help. Please don't take this into your own hands and attempt to rig something up, unless you're a professional. Especially when you're smelling gas during pre-heat. Here's their contact info:
Preway Service Inc.
Appliance Repair Service
27 Rocklyn Ave.
Lynbrook, NY 11563
(516) 593-1316
Aug 26, 2014 • Ovens
Black smoke coming from oven while preheating
If you are getting soot residue, it could be a number of things, First, is this a natural gas or propane oven? If you bought an oven to be used for propane, it may need to be converted from natural gas to propane or it will soot everything up. 2nd, have you recently spilled food/liquid onto the oven burner? If the burner holes are partially plugged, the remaining holes will burn large yellow flames and soot up the oven. Check the burner flames, they should be mostly blue with little to no yellow tips. Also make sure the oven burner flames are not too big. They should never exceed the width of the flame spreader pan directly above the burner, in fact they should be less than half the width. You could also have other issues like improper air shutter adjustment to the oven burner or very low regulator pressure, but most likely it has just been spilled on recently.
It take a long time for the oven to preheat and some time you can smell gas during the preheating
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
1helpful
79012 / 79014 / 79019 Gas Kitchen Range: The propane converson seems to be done right, howe...
It sounds like during the conversion process a step or two may have been missed.
The gas orifice for the main oven burner is most likely to large (was not converted to LP), or the air shutter on the burner was not adjusted. I would not use the oven with the flames that way.
There should be instructions with the installation instructions on how to convert the oven, basically on most oven burners the orifice is screwed down (tightened) until the flame is the right size, then the air shutter on the burner is adjusted for a blue flame.
Let me know if you have questions
2helpful
3answers
Whirpool gas range - propane gas not sure oven is working right
First, the flame should be blue and without much visible yellow. You need to give the gas tube a good cleaning to get out any soot buildup and any partial obstuctions that might be causing the problem. Since you started with a yellow flame and soot, you need to get the burner tubes clean to see if you have resolved the problem after adjusting the regulator and burner valve(s).
You might need to install a different regulator to match the pressure of your gas supply source, as regulators have a specific working range of inlet (supply gas pressure) that they can operate properly at to "regulate" the supply pressure to the stove's needed pressure.
Check your manual and the installation guide to verify what the gas inlet pressure requirements are and check with your gas supplier to see what they are providing you.
To your 2nd question, yes, the gas will cycle on and off when you are using the oven, since the thermostat will call for more heat when needed and shut off the gas/flame once the temperature you set the control at, has been reached. The cycling is a result of the oven trying to maintain the desired temperature for baking.
One reason that you can smell gas when the oven is being used, is because all gas ovens have a surface vent to allow excess heat to escape from the oven compartment, however you should not be smelling raw gas (actually you're smelling the "rotten egg" additive that's put in the gas) all the time, since when the oven is turned on, a small electric ignitor is heated up VERY HOT glowing bright orange inside the oven compartment. Once it's hot enough a sensor opens the gas valve and lets gas into the burner tube to be ignited instantly by the VERY HOT ignitor. It is rare to smell raw gas with this system, but sometimes you'll get a stronger "rotten egg" smell at different times due to the gas company and their system, etc.
As to the gas smell, you should NOT be smelling gas every time the oven cycles on when baking, as a normal ongoing occurrence. During the first few uses, it is normal to smell some gas, but this should go away after a couple of uses. If it doesn't, you should look to make sure the regulator and oven controls are PROPERLY configured and set - Since you've already fiddled with these, it's probably a good idea to have someone from your gas company (or a gas appliance tech) come out and do this. Improper settings can cause some serious problems.
Hope this helps!
Oven flame ignites but will then not increase to the larger size
when oven is switched on the flame ignites,butthe flame refuses to go tothe next stage to preheat the ovento the required setting
Gas oven
Inspect your flame tube to see if all the holes have a nice blue flame coming from them.
If the flame is not coming from all the holes or the flame is yellow or orange with some soot build up, then have a qualified technician service the unit immediately.
Do not use the oven until it has been inspected and certfied safe.
Dave E. (Illeagle)
Top Whirlpool Kitchen Ranges Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
