I work in a motel and replace these heaters quite often, Cadet C202, a 240v 2000 watt wall heater. Most of the time when they blow cold air it's because the heating element is broken. First turn off the circuit breaker, then remove the heater from the wall. If you take out three screws, slide the top cover off, bend the two little tabs and take out the heating element, you can examine it and usually you will find a place where it is broken, it's like a big spring. Replacement elements can be ordered from online stores such as reliableparts.com Be very careful, 240 VAC is very dangerous! <!-- from fixya rte -->
Hi!
Do you have full voltage to the unit? Check that first. Then check if you have voltage to the elements, if you do then your element(s) are bad. You could also ohm out your elements if that is easier for you. If you have voltage to your thermostat but none getting to the elements then your thermostat is most likely bad. Hope I was of help to you!! Good luck!!
