Kitchen Ranges Logo
Anonymous Posted on Dec 31, 2009
Oven door still locked after clean cycle
The small oven door on our VDSC 485 Viking stove is still locked 24 hr after the auto cleaning cycle. Any suggestions on how to release it?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
364
Points
Take off the burner platform over the oven. Slide out the drip platform completely. Remove the access plate over the oven (Use a Phillips head sideways in a locking wrench to loosen screws). Using a long screwdriver slide the locking arm to the left of the oven as you face it, jiggle it a bit and it should release. I hesitate to clean the oven again but at least I now know how to release the lock and I saved $150.00 from my local appliance repair bandit.
My Viking electric oven will not self clean, any suggestions.
Ensure the door is closed securely if the Viking oven will not enter the self-clean cycle. If the door is not closed completely, the door lock cannot engage to start the self-cleaning.
https://www.hunker.com/13408313/how-to-troubleshoot-a-viking-oven
1helpful
How do i lock the self cleaning ge oven door when i put it on self clean
If you have a self cleaning oven, the door will lock automatically as the self cleaning begins. Give it some time ,it will happen. When cleaning is done it will take a while for the door to unlock. GOOD LUCK FRIEND.
Stove will not self clean
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
2answers
How do I get self clean to work on older fridgidare stove
Move the safety lock/lever at the top of the oven door to the right and press the self clean button on the oven control panel, it is an automatic cycle so it will lock the door from opening and then will proceed with the auto clean cycle. Good luck !
VIKING STOVE DOOR IS LOCKED AND WILL NOT OPEN , STOVE WAS IN A SELF CLEANING MODE AND DOOR WON'T OPEN AFTER CYCLE COMPLETE
unplug or turn off breaker to stove for 10 minutes...then try to gently open.....the oven has to be completely cool before it will unlock....when cleaning is done release lock before turning cleaning off
I cant get my viking 30inch electric range to self clean. it has a self clean spot on the knob and on the temperature knob but when both in place nothing happens.
You might need to lock the oven door to get the self clean to go on. My stove had a lever which locked the oven door when you pushed it sideways. It was in the middle above the oven door, in the gap... Hope this helps!
1helpful
2answers
Oven Lock stuck open before start of self-cleaning cycle
Sounds like you bent the door where the lock is. You might have to replace the door.
2helpful
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 • Ovens
8helpful
6answers
Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
1helpful
Whirlpool Flat top Accubake self clean 24 inch
Of course - Empty the oven and clear off around it.
The AUTO-CLEAN cycle time is adjustable, from 2 hours
30 minutes and 4 hours 30 minutes in 15-minute increments.
Suggested clean times are 2 hours 30 minutes for light soil and
4 hours 30 minutes for heavy soil. The last 30 minutes of the
cycle is for cool down.
To Self-Clean Using AUTO-CLEAN
1. Press AUTO-CLEAN.
2. Press the TEMP/HOUR “up” or “down” arrow pad to set the
desired self-clean cycle time.
3. Press START.
The oven door will automatically lock. The “DOOR LOCKED”
and “CLEAN” indicator lights will be displayed. The time
remaining will also be displayed.
4. When the self-clean cycle is complete and the oven cools,
the “DOOR LOCKED” and “CLEAN” indicator lights will turn
off.
5. Once the oven is completely cooled, remove ash with a damp
cloth.
To Delay Start Self-Clean Using AUTO-CLEAN
2. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired self-clean cycle time.
3. Press START TIME.
4. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired start time.
5. Press START.
The oven door will automatically lock. “DOOR LOCKED” and
6. When the self-clean cycle is complete and the oven cools,
off.
7. Once the oven is completely cooled, remove ash with a damp
cloth.
Owner, Warranty, Installation and Parts manuals are here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=sf362lxst&siteCd=WHRCOM
Sometimes search links don't work when copied.
Here is the direct link to the Use and Care Guide:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10110369.pdf
Page 16 has the above instructions.
God Bless!
-Ptochos
Top Viking Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
