I recently did a full tune-up on a friends VW jetta. He drove it for quiet a while with the (feels like the transmission slipping) By cleaning the throttle body, it helped it to shift better. It can be cleaned by removing the Air filter and housing, Spray Throttle body cleaner into it with the throttle open. Wipe clean with a none shedding rag. Repeat the process. The cleaner dries fast, but let the car sit for a few minutes. Put housing and filter back on. It may seem hard to start after, it's because the cleaner. it's no big deal. Unless You rather for the VW dealership do it for around $300.
Transmission
gear assembly and transmission needs inspection. Also check the transmission
fluid level. Also is the fluid getting leaked or its low.
There
are few very helpful links with solutions to troubleshoot this problem.
I
suggest you to refer these links.
Click
the link below:-----
2000 Toyota Camry: Transmission slipping and Stuck up?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-transmission-slipping.html
Transmission Slips out of 2nd gear?
http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
Car engine Overheats and transmission starts slipping?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
2006 Ford Explorer: Engine Vibrates and gears slipping?
http://whatisbyme.blogspot.in/2012/06/2006ford-explorer-engine-vibrates-and.html
Clutch slipping problem?
http://howtobyme.blogspot.in/2012/03/clutch-slipping-problem.html
Dodge Anti slip System is not operating?
http://whatisbyme.blogspot.in/2012/07/dodge-anti-slip-system-is-not-operating.html
OD light flashing and transmission fluid leaking?
http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
Transmission fluid leaks near radiator on ford windstar?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
Ford Windstar transmission fluid leaking?
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
TRANSMISSION REPLACING AND
TROUBLESHOOTING
http://alltypesofpartsreplacing.blogspot.com/2012/12/transmission-replacing-and.html
These
details will help.
Thanks.
