Question about Redhead Optics
I need a replacement rubber eye guard for the eye piece on my read head spotting scope. Any ideas?
Posted by debi973 on
Anonymous
I'm looking for a replacement eye guard for my finder scope and this place looks first class!
http://www.anchoroptics.com/catalog/product.cfm?id=195
Eric in NZ
Posted on Jun 23, 2010
We had the 20mm eye piece in and we turned the focus all the way clockwise so the eye piece was all the way in. We had the cover off, we had a very clear starry night, we live in the country, moved the...
First find a local Astronomy club -- the members will help you.
Second, you must first align the red dot finder with the main tube-- there are knobs on the side and bottom (usually) to move the red dot. Point the scope at the top of a telephone pole in the distance during the day time-- wget the top in the center of the eyepiece of the main tube. Without moving the main tube adjust the red dot so it points at the exact same spot.
Turning it all the way in or out is NOT how you focus-- there is a small "spot" when the eyepiece is in focus, and every other eyepiece must be refocused. Turn the knob slowly until the star or the moon comes to sharp focus.
Read my tips on my profile page.
www.telescopeman.org
www.telescopeman.us
www.telescopeman.info
Jul 04, 2011 | Celestron AstroMaster 114EQ (100 x 114mm)...
Need the rubber eyegaurd for a Bushnell Sportview rifle scope
if you need the rubber eye guard for this rifle scope you are using it all wrong,,,if your eye is so close to the end bell of the scope your going to get a very black eye,,,there is at least 2 inches of eye releaf on this scope so there is no reson to have a rubber bit on the end at all, i have 3 of the bushnell scops on my rifles a ,,,7.62,, .303,,,22.250 and none have the rubber on them,,,so far iv never had a black eye!
Nov 15, 2009 | Bushnell 3-9x38 Sportview Rifle Scope...
The rubbers on the eye pieces are deteriorated are they available anywhere
You'll need to measure your eyepiece in "mm". Also determine if your eyepiece has an outer ring the eyepiece will slip over. You can find eyecups/guards on Ebay. Search under Binocular Eyecup or Binocular Eye Guard. There are also eyecups under "rubber eyecups/rubber eyeguards" but alot of these are for Microscopes and may not fit. You will need to pay close attention to the mounting type and measurements.
Sep 22, 2009 | Tasco Off Shore OS21 (7x50MM) Binocular
Replacement parts for Tasco binoculars
Sep 18, 2009 | Tasco Wide Angle and Rubber 2023 (10x50MM)...
Looking for an item - eye guard for scope on a gun
Pictures of the exact item along with any markings would help a great deal. Even a hand drawn sketch along with dimensions would help.
It sounds as if you may be describing a scope cover. One end cap is clear and the other end cap either clear or has a yellow tint.
Most all current covers have the end caps attached to each other using two stretchable thin bungee like cords although some do have a one piece rubber holding the end caps.
If this is what you are looking for any sport shop, most discount stores and such carry them.
I attached a picture of this type of cover.
Mar 22, 2017 | Tasco Golden Antler 3 - (9 x 40 mm)...
Missing eye relief guard - rubber
I would try Midway.They have about everything for anything related to optics and hunting.I have used them for years.www.midwayusa.com...Good Luck
Dec 22, 2008 | Bushnell Banner Dusk & Dawn 6-18x50...
15x45 eye piece
call [email protected] for your nearest distributor good [email protected]
Nov 19, 2008 | Bushnell Optics
RA11 A Spotting scope
I did a little research for you. Check your manual but I think your "eye piece" has a 12.5mm thread into the body of the scope. The FSA-L1 has a 15.2mm thread which goes in the place of and replaces the eye piece for the models it fits. Check that manual too. If you have calipers you can verify it too by measuring the male thread of each. What you need if you can find it is a 12.5mm (male) to 15.2mm (female)adapter. Becareful it doesn't change the focal length. Check with photo shops or on-line. I'll do a quick search too and repost if I find one.
Jul 16, 2007 | Nikon Sky & Earth 7455 (20-60x80 mm)
Optics Logo
449 people viewed this question
Top Redhead Optics Experts
Marvin
Marvin
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Redhead Optic Expert? Answer questions, earn points and help others
