hi,
First You have to check the lamp cooling fan. if the fan didn't run at the correct RPM then the lamp will not get proper cooling and the lamp will get over heated. This will result in termal shutdown. And the tv will go to standby to prevent from burning the lamp. Just replace the fan. If the problem remains after replacing the fan then the problem is wiih lamp blasting circuit. If so you have to replase the lamp blast.
ok
The projection lamp inside on this tv,about 1 1/2 or 2 years,tv on and watches about 4 or 5 hours a day?The projection lamp life are over.Tv require a new projection lamp.
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
power pack capacitors have failed they will need to be replaced with new ones and that should repair the tv, soldering skill is required to do this or replacement of the entire power pack. hope this helps
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
