Verizon Communications enV2 Cellular Phone Logo
Question about Verizon Communications enV2 Cellular Phone
The internal screen is not lighting up. I got a text from my husband then placed the phone in my bag. I pulled it out 30 minutes later all was working except the internal screen. the phone was not dropped and i do not remember pushing any buttons.
Posted by tiberpold on
I have a samsung u350 I don’t see a place for a SIM card husband isn’t smart phone smart is there a way to put a SIM card
You might be using CDMA type of mobile phone wherein you are not required to use a simcard since the network identifies a handset by the information stored in the internal memory and hence, its handset specific. You might want to check if its working though by checking some signal bars usually at the left or right corner at the top of the screen, doing some test calls and send text messages. If everythings working then you're good to go. :)
2006 kia sportage ex..engine was running..now want spin over
The SRS is connected to the fuel pump as a safety measure. What happened is the fuel pump cutoff is active now.
My phone has no power even when plugged in
Remove your battery, rub golden points with an eraser..and then place it again. make sure the black marks on the golden points have reduced and there are no leftover from the rubbing which get into your phone.
Otherwise:
Charger port might have stopped working.
Or check if your charger is working properly.
Touch pad not work
pull out your bettry for and take your phone at sun light 30 mint later pick up your phone and put bettry and turned on, mostly some touches got problem like this
My husband has heart trouble and to date, has 15 stents. Is there a way to disconnect the air bags in a Chevy Cavalier? He is a dead duck if they go off and crush his chest.
Yes disconnect both cables from battery wait 30 minutes.Then there are a couple of screws in the back of the air bag.Pull off and disconnect wire and replace air bag.Place the cables back on the battery
4helpful
2answers
My driver side electric window keeps off the tracks on my 1997 E230 Mercedez Benz. We are worried about SRS airbags will deploy if my husband tries to fix it, as we dont have a manual for the interior of...
You can disconnect the fuse to the air bag system and wait 30 minutes and remove the door panels but despite all the warnings about the air bags going off it takes forceful impact or using a jumper wire hooked to a battery to set the air bag off so you have nothing to worry about.
1helpful
I accidentally dropped my phone in a basin of water. Although I pulled it out immediately, I wonder if I have damaged it to the point where I need to purchase a new one. Currently I cannot get it to turn...
Try to get it dry keep it in hot place after removing the battery leave it for 2 days and then try to charge the phone, check when you switch on the charger any sound comens of starting the chargeing process, if possible try the phone with some other battery, as the service center is saying it cannot be repaird may be the interner circuits may have fgot damaged
You can also use a hair dryer after opening the cell phone.
Do not put the battery on or switch on the cell till the time you are not sure its dry completely.
You can also try this leave the phone in a bag of raw rice for a night it will become dry as the rice will soak the water
Check if this helps & let me know
The internal screen is completely black when it's
mine did the same....im taking it back to verizon to get it replaced later this week
Touchscreen not working buttons working
turning it off doesn't do much if you don't pull out the battery. Turn it off, pull the battery and let it stay out for 45seconds - a minute. then try again. be patient and don't tap the screen until it prompts you.
My husband threw out my motor bag for my Delonghi Wet and dry M-31. Can I run the vacumm without this protecting the motor?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=538790
Generic problem for all Vacuums
Delonghi Wet & Dry M-31
Posted by bcpercy on Apr 23, 2008
My husband threw out my motor bag for my Delonghi Wet and dry M-31. Can I run the vacuum without this protecting the motor?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
No…. I would advise NOT running the machine without the filter because you will burn up the motor. You can use a paper bag with a rubber band to slide over the motor to protect it from dust and also if you have a foam type filter – you can put the foam filter on first, then the paper bag then the rubber band, or if you have a cartridge filter you can run it with just the cartridge filter bur would suggest cleaning the cartridge filter after each use – also you can place the paper bag method over the cartridge filter as well or call the Delonghi factory and order the part or they will direct you to a local dealer, Info listed below:
http://www.delonghi.com/Int/USA/menu.htm
Mailing address:
Fox International, LTD., Inc.
23600 Aurora Road
Bedford Heights, Ohio 44146
Customer Service – Sales 1-800-865-6330
Customer Service – Fax # 1-800-445-7991
Email: [email protected]
Email – Sales sales[email protected]
Business Hours
Monday thru Friday 8:30 am to 5:00 pm EST
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 23, 2008 • Vacuums
Top Verizon Communications Cell Phones Experts
Marvin
Marvin
David Shaub
shadow
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
