SOURCE: Dishwasher
if you installed a new garbadge disposal at the same time have you popped the factory drain plug on the disposal where the dishwasher drain tube connects to the disposal. The plug is inside the disposal dishwasher connection tube . You cant see it . Just drive a screw driver through it with a hammer.Itt will pop out and then the dishwasher will drain.Just a thought.I forgot to do this to mine.
SOURCE: maytag dishwasher jet clean eq plus water not filling
My Maytag Jetclean Flexiload is 4 years old. Upon choosing a program the timer counts down but little action is heard. Near the end of the cycle an Error message comes up. The dishes are stiil uncleaned.
SOURCE: Maytag Jetclean Dishwasher EQ Plus MDB7100AWB
the door seal has gone better change the door surround seal also. check for case damage and obstructions aswell.
SOURCE: Maytag jetclean EQ plus dishwasher
If it is a wire disconnected to the motherboard all you need to do is solder it back on. You need a solder GUN, not a solder stick. Use solder with resin already in it.
Only do this if you are good with a soldering gun, as if you get too much solder on you will destroy your motherboard.
