Question about Digital Audio TRIO MP3 Player
I got a mp3 digital audio player. The volume control is frozen at 10. I can not pull the volume control to adjust the volume up or down. HELP!
  • p_cato Dec 31, 2009
    I would like to ask another expert.
  • 4,472 Answers
If you just purchased the unit then you will want to return it for a new one as it is most likely defective. If you need any further assistance please let me know.
Thank you,
Lee
Posted on Dec 31, 2009
  • 298 Answers
The firmware must be corrupted. You can update it using this as your guideline: http://www.machspeed.com/tech/firmupdate.html
Volume adjustment polaroid mp3 player
the ring on below the screen is the volume controller and also work as scroll up down.
Mar 10, 2013 | SanDisk Sansa e260 MP3 Player
My Sansa fuze is frozen! Help! It was connected to a laptop computer. I shut down the computer & THEN disconnected the fuze & now the fuze appears to be frozen....nothing at all happens when I push...
In order to solve this problem you have to push the 'off' switch toward the power button. Hold it for roughly about 10 seconds and it will automatically shut off. Hope this helps =)
Dec 28, 2010 | SanDisk Sansa Fuze MP3 Player
The volume control is frozen on the lowest level.
The manual gives next steps to setup the volume:
1. Press Menu button to return to the Main Menu.
2. Move down to Settings and select it.
3. Select Volume.
4. Highlight the desired volume settings then press Select button.
Manual in pdf format for the Sansa Clip:
http://mp3support.sandisk.com/sansa/UserManual/CLIP/CLIP_UM_English.pdf
Dec 19, 2009 | SanDisk Sansa Clip MP3 Player
Sony walkman nwza 818 volume control button wont turn up! I press the plus button on the volume control located on the side of the mp3 player, and it does nothing yet i can still turn it down! please help
My Sony MP3 player's volume control button wont turn up! I press the plus button on the volume control located on the side of the mp3 player and it does nothing yet i can still turn it down! Please help
Jul 29, 2009 | Sony Audio Players & Recorders
Audio slider does not work
I have the same problem. After trying the adjust the volume on the screen, it went all the way down and slided back to mute everytime after I pulled it up. The volume button on the right didn't work either. I called Archos tech support on Feb 13, 2011 and they said they no longer fix this product because it's 4, 5 years old. But they would offer me a 15% discount for an upgrade. Why would I want to buy the same brand again if it's so unreliable?
Mar 27, 2009 | Archos 605 WiFi Digital Media Player
I have a sharper Image mp3 player cant figure out
With music (or whatever)playing hold down V button (left hand side of control circle)til volume adjustment screen comes up-a blinking speaker. Press PRE or NEXT button (top and bottom arrows) to adjust volume.
Mar 04, 2009 | Sharper Image 1612911 MP3 Player
Volume control problem
Your volume control switch in the cirucit is damaged - call Philips and find out if you are still in-warranty.
-Tha Mp3 Doctor
Feb 22, 2009 | Philips HDD1630 MP3 Player
When I connect it to either of my computers, it keeps transferring but won't connect anymore. It's an ILO 2GB Digital Audio MP3 player. HELP!!!
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up.
2)
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
Mar 09, 2008 | iLO (2 GB) MP3 Player
Iriver e 10
how to use the remote control.
1. go down to settings
2. remote control
3. find your tv brand (mines in ect(more brands))
4. point at tv (when on)
5. Scroll down list of numbers (#00; #01; ect)
6.go down to the bottom and if your tv dosn't turn off your tv isnt supported.
7. If it is supported click on the number your tv was
8. go back to the main menu
9. put it on hold (switch on side)
10. your done!
controls are:
up - channel up
down - channel down
left - volume down
right - volume up
power - off/on
smart key - mute
vol up - volume up
vol dwn - volume down
Jan 19, 2008 | iRiver E10 Digital Media Player
Craig mp3 player
Reset the Device
NOTE: THIS IS AN ADVANCED OPERATION. NORMAL USERS ARE NOT RECOMMENDED TO PERFORM THIS OPERATION!
Sansa e200 provides a Reset Function. Please note that you only need to use this function if the device does not respond for several minutes. The button is like a power down button of the device. You can turn off the device by using a reset operation, such as pressing and holding the Menu button for 15 seconds. Once you perform the reset function, the adjustments you made during last
30
Dec 27, 2007 | Philips GoGear HDD6330 MP3 Player
Digital Audio TRIO MP3 Player Logo
50 people viewed this question
Top Digital Audio Audio Players & Recorders Experts
Ibrahim Makki
Level 1 Expert
ray gallant
Tom Chichester
Are you a Digital Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
