Question about Vacuums
Kenmore vacuum model 116.3592250 works fine, burn smell
Kenmore 116.3592250 works fine, smells like burning while running. No belt, not sure where to start. Bag is not full
Posted by srumsby on
Chuck Earls
  • 231 Answers
Is that the one with the direct drive brushroll? those brushroll motors inside the brushroll always go bad. that is one of the worst designs from kenmore. is the brushroll turning?
Posted on Jan 04, 2010
Burning smell Kenmore 50558
If the burning smell is an electrical smell it could be motor or wiring problems which are best handled by a professional. If it smells like burning rubber it is probably the belt. If it smells like burnt wood it could be the belt slipping on the brush roll, if the brush roll is made of wood. Dust and debris can also accumulate behind the end caps of the brush roll causing friction which can cause a burning wood smell.
Mar 30, 2014 | Kenmore 5055, 50557 and 50558...
I have a steam vac spinscrub carpet cleaner works good but it just started smelling like it was burning and started to smoke
Anytime someone says they smell something burning on any type of vacuum cleaner of carpet cleaner etc. All I can think of is the belt is rubbing on plastic which would cause the sense of something burning because you possibly are smelling the belt........
Mar 12, 2014 | Hoover SteamVac F5914-900 SpinScrub...
My Kenmore model 116 33300300C smells like burning when we use it. The bag has been replaced
If it is a burning rubber smell it may be the belt slipping. Make sure your brushes are clean and spin freely and then put the belt back on and see if that helps.
Apr 05, 2011 | Vacuums
My vacuum was working fine, then started to smell a little funny like something was burning. Turned it off. Now when you turn it on it will run for a few minutes and then shuts off, like something is...
The smell is usually the fan belt. When the brush is stuck in place, the belt spins and burns. Check to see if the brush is free to spin. If the Belt is burnt, it needs to be replaced.
Jan 31, 2018 | Kenmore 28015 Bagged Canister Vacuum
Dirt Devil Jaguar Bagless Upright Burning Smell
take the belt off again you will see burnt rubber from the old belt stuck to the motor shaft.you can take a fine piece of emery cloth and clean the shaft down to its polished finish.always good to do this after each belt.check the brush roller and see if there are any signsd of plastic melted.make sure it turns freely if not the brush roller might be siezing uo on youhave you cleaned the hepa filter?does it smell like wires burning or rubber.with it unlugged take it apart to the motor and take a fine iece of emery cloth and go over the motor armature .then try it again.you can take all the filters out and run it without the filters.that will help you narrow it down.please leave feedback
Mar 15, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Burning rubber smell when the vacuum is on.
it sounds like the belt may be burning like the roller bar is stuck maybe or the belt is stretched and is burning itself off
Jan 11, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Thr brushes are not spinning and it smells
That is your belt burning, turn the vacuum upside down and make sure your brush is spinning freely. Something may be wedged in your brush.
Dec 27, 2008 | Kenmore 85920 PowerSpin Upright Wet/Dry...
Sebo x1.1 - burning smell
Try replacing the belt. My vacuum cleaner had the same problem and once the belt was changed the burning smell was gone.
Jun 10, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Burning smell and smoke
When you turn it on....is the belt turning the brushes? Something may be caught causing the brushes to stick and the belt to just grind the brush assembly.
Jan 03, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Vacuums Logo
552 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
