Hi My Epson c900 either prints but creases the paper up or it comes up with a jammed paper signal while the paper is still 1-2 cm inside the machine. I have just bought a second hand machine that is doing exactlt the same. Can you help please? Regards Steve
Clean your roller and see if there are loose gears or trapped objects
inside. As for the faint prints, check your toner density. The normal
setting should be 3
check the toner ,, check paper jam and ,, paper tray ,, or any sensor issue,, don't give the print order untill you see the green signal over the printer...
Is media transparent? Epson paper sensor think that no paper. Put white stiker at top left and right of media (about 1 cm height and 2 cm width). It's for tricky sensor.
We just solved this problem with our c900.
Basically, a paper jam has caused some probs with the sensors and rollers. After playing with the thing for about 4 hours, i ran some really thick photo paper through it and after a couple of trys where it just screwed up in the back, it then fed through and printed correctly. After that it was fine with all paper types, no more messages, and no more paper getting screwed up in the back. Ian
still printing but the paper goes no further?. It may be the paper is locked by paper feeder mecahnics, Open case, check it, and may be there is something "material" broke.
Step1 Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred. Step 2 Turn off the printer. Step 3 Remove any paper trays. Inspect them for wrinkled or damaged paper. Step 4 Open any other doors that give access to the printer's paper path and to the toner or ink cartridge. Step 5 If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it. Step 6 If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam. Step 7 If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though. Step 8 Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on. Step 9 If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
OK after messing about with the drivers I got it to work. I downloaded a driver from Epson singapore and it made no difference. So, I re used the driver from Epson UK and hey presto the thing works again. Why? Good question. Maybe the people in Epson have no idea either.
So, I suggest deleting the driver rebooting the system and reinstalling it. I hope you get it working.
