Question about Polaroid FLM-2632 Television
Polaroid FLU-2632 LCD TV full HD 2 HDMI problem
Hello, I have a Polaroid FLU-2632 full HD 2 HDMI sockets.
I have connected a DVD HDMI player Via the HDMI cable
It will not display a picture on the TV. I have tried 2 different DVD players one a blueray and the other a DVD upscalling player via the HDMI sockects.
This TV is full 1080 HD ready and whatever I do It doesn't seem to work. I can only get a picture when I connect via the YPbPr but this is no good as is its not a Hi Def picture
Could anyone please advise, its driving me nuts
Thank You in advance.
Posted by Rainbows_End on
Wbix
    Master:
  • 364 Answers
You could try pressing the source button on the remote to see if that brings it up.
Also the TV may have got itself in a muddle. There will be a way to reset it to factory setting. If you can get into the TV's setup menu there ought to be an option buried somewhere to do that.
Posted on Apr 28, 2017
5 Related Answers
Anonymous
SOURCE: polaroid tv flu 2632
Try 11498 or 1498 (for 4 digit remotes)
Posted on Jun 26, 2008
Anonymous
  • 15 Answers
SOURCE: Polaroid FLM-3232 Blue Screen 'No Signal'
yeah stay away from polaroid! In the meantime check this out.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Posted on Jul 22, 2008
Anonymous
  • 317 Answers
SOURCE: Basic help with connecting new mini-flat screen to new mini-dvd player
use dvi or hdmi.
Posted on Aug 03, 2008
Anonymous
SOURCE: Poor reception when connected to cable (no cable box); DVD player will NOT accept discs
I called Polaroid Customer Service.
Thanks
rosemary38
Posted on Aug 20, 2008
Anonymous
  • 814 Answers
SOURCE: polaroid flm-2632 remote codes
You can find the code for direct tv in your owners manual on page 53 . If you do not have a copy of the owners manual. This customer support website for Polaroid. http://www.polaroid.com/CES/SupportProductDetail.jsp?prod_code=PT120&folder_id=0 has a pdf copy. You will find the codes you need on page 53. If you cannot find the correct codes for direct tv . Call Polaroids customer support at this telephone number 1-866-289-5168 and they will be able to tell you how you can find the codes. I hope this information helps you with your problem.
Posted on May 28, 2009
How can I connect my dvd player to a Philips 32PFL5605H/05 32-inch Widescreen Full HD LED TV ? It is of the type which has one red, one yellow, and one white connector but i do not see any sockets that...
The included cable with the red, yellow and white RCA connectors is a composite A/V cable. To connect this cable to the TV, you need a SCART-cinch adapter. Then use one of the SCART connections on the TV. Note: the SCART connection does not handle HD signal.
You will get a much better picture if you buy a different cable. Depending on your DVD player, get either an HDMI cable or a pair of cables - a component video and audio cable. (Both component and the audio cable will have RCA plugs at each end. The component video has 3 plugs - red, blue and green. The audio will have 2 plugs - white and red.) Both of these will carry HD signals. Most DVD players will have at least component video and composite video jacks; some have the HDMI output. Most DVD/VCR combinations will need the composite video for the VCR and the component video is optional for the DVD signal.
I hope this helps.
Dec 24, 2010 | Philips Televison & Video
I have an longtime problem with my flm 3232 polaroid hdtv. I have dish network service with the dual receiver. The 3232 is the second tv connected via a coax cable. it work fine on the tv cable input...
Hello, you probably already have gotten this resolved, but I do have some answers to your post. Any cable that you have running from TV1 to the TV2 will nor give you a true HD picture. You could get a CAT5 cable with HDMI ends, but the longer the cable, the less true HD you have. The best resolution to this is to get an additional receiver, or to just stick with the SD picture. If you have any more questions, feel free to e-mail me at [email protected], or you can find us on Twitter!
Becki Barned
DISH Network Customer Service
Oct 14, 2010 | Polaroid FLM-3232 Television
I can't get tv to send sound to sound system
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
DIRECTLY FROM THE USER MANUAL
source from
http://tv.manualsonline.com/manuals/mfg/polaroid/polaroid_flm_flm2632.html
? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
METHOD A:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
OPTICAL OUT jacks.
METHOD B:
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
COAXIAL OUT jacks.
Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
May 25, 2017 | Polaroid FLM-2632 Television
How do i hook my dvd player to my tv? i have no manual to show me where to plug the wires into the back of my tv.i have a proscan 32LB30Q LCD
Hello pebbles12137,
This depends on what you want to do SD or HD
First if you just want to connect for SD only
Here are Three ways:
1) connect the coaxial cable to the DVD player F-connector (sliver screw connector) and the to the TV's Antenna in F-connector.
2) connect the yellow, red and white RCA connector end wires to the yellow, red, and white RCA Jacks of the TV Yellow (video in), Red (Right Audio in), White (Left Audio in) do the same for the other end into the DVD player (Best SD Method)
3) connect the svideo cable into the s-video socket of the TV and the other end to the s-video socket of the DVD player
For HD, Here are the connection methods:
1) Connect the HDMI cable to the HDMI in of the TV (HDMI1)and the other end of the HDMI cable into the DVD player. (best HD method)
2) connect the Component video cable (RGB) into the RGB sockets of the TV (should be marked as Component 1) and connect the other end to the DVD player (using this method you will have to connect the Red and White audio cables to the audio input jacks of the TV from the audio out of the DVD player)
These are the SD and HD methods.
I would suggest using the HDMI cables only, its the best choice and the simplest.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jun 21, 2009 | Proscan 32LB30QD 32 in. LCD TV
No sound
Are you using a set of sound wires in addition to the HDMI cable? - HDMI only carries the HD Video and no audio, so you still need either a digital or audio cable to pass the audio to the set.
Aug 30, 2007 | Polaroid FLM-2632 Television
Polaroid FLM-2632 Television Logo
238 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
